Starting when the engine is hot
08.05.2020 18:47 # 1
ayazonur
Good evening guys;
When I start the engine with the 2004 model LPG 307 im engine, it just clicks and there is no starter. The car is running when the engine temperature is around 90 °. Is this a malfunction in the engine, or is the vehicle not running when it is too hot to protect the engine? ayazon is 2014-09-04 23:57:25
08.05.2020 18:47 # 2
ayazonur
Friends, do not have any information about this subject ..
ayazon is 2014-09-05 11:08:56
08.05.2020 18:47 # 3
ayazonur
08.05.2020 18:47 # 4
Emask
My friend is probably the starter's cellonoid is faulty.
08.05.2020 18:47 # 5
alitekeli35
FRIENDLY
I do not believe you have the same problem in me 2 months
After I bought the car, I had a problem with the peugeot 307 2003 sw sweat.
I do not have any problem with the temperature anymore. However, in the last 3 months, there is a problem you are saying.
I saw the car at 90 degrees and when I stopped it from the moment, it did not work again for at least 10 minutes in both the grocery store and the short-term stops. In the peugeot fan system, which has 2 stages, activate the second fan at 95 degrees, as well as the air conditioner. I can not destroy the object. If you are sure that you bought the car without any maintenance, you can change the part that your friend said before me. If I do not have a master from erntten.
ALİ M. TEKELI 532 367 24 87
08.05.2020 18:47 # 6
ayazonur
Hello hello Ali;
I do not think that this is a malfunction, I think the vehicle cuts the starter to protect the engine when the engine temperature reaches 100 ° to prevent it from starting (When the engine gets too hot, the pistons will also expand and damage the cylinder and the piston at the first start). There are so many vehicle owners who have faced this problem and no one can get any results from the service, it created such a theory for me, but if we learn anything about this issue, let's share it here.
08.05.2020 18:47 # 7
ertanakar
Also check the sockets of the relay that separates the LPG and the gas pump..only advice ..
08.05.2020 18:47 # 8
suppor
The same problem the master had was with me, while the engine was hot, it worked while waiting for it to cool or cool while the seals were cold.
The problem is that the friends who are in mars automat change the bidet commands when they are ready 10 20 TL
08.05.2020 18:47 # 9
alitekeli35
thank you support i will make it right away if you say the problem continues, let's share it here
08.05.2020 18:47 # 10
alp2525
the same problem was with me in the old 307, the problem was with the starter automatic. The starter motors did not change completely and there was a repair kit, so the problem was resolved.
08.05.2020 18:47 # 11
suppor
I gave the starter 100 to the commanders and 75 in 20 jobs.
08.05.2020 18:47 # 12
alitekeli35
hi friends
The problem previously written in the forum, as our support friend said, is from the mars automat. 100 tl valeo
I gave 50 of them as a whistle.
Thank you so much for your support and other friends
I have a new problem started and I wanted to share it. The vehicle vibrates incredibly at idle. There is no loss of power, traction, or an increase in lpg and gasoline.
thanks
08.05.2020 18:47 # 13
suppor
my brother is not something :)
Since my vehicle is a diesel, I can't say it.
