starting problem
08.05.2020 18:25 # 1
mican69
receptivity 2014-03-30 22:12:25
08.05.2020 18:25 # 2
mican69
friends at Ş.urfa hilvan my teacher took my car for 6 months or so since the day I bought it was very rare in the beginning, but it has been very rare at the first 2 months. No, I thought you will help me. What is the need to see an emergency repair? I hope someone will help.
08.05.2020 18:25 # 3
Alicilik
People who are more knowledgeable than me will surely come out. It is not a situation I encounter, I will not be able to comment too much
It looks like a starter motor, but as I said, it has no accuracy.
Get up to date.
08.05.2020 18:25 # 4
mican69
Thank you ali ins.
08.05.2020 18:25 # 5
307Mster58
If the oil is old, you can make it look very good in the winter. I think the injector works in the language of the industry. The spraying place is like flowing from the tap. If the oil is cheap, the requirements of the engine are not met.
08.05.2020 18:25 # 6
mican69
I had the vehicle serviced two weeks ago, shell oil was put in. As soon as you said, I will have the injectors checked.
08.05.2020 18:25 # 7
ahmet_bjk
I do not know the system exactly, but it has to be gear to transmit the rotational motion. It seems to me that some of the gear of the starter motor is worn. It may be operating when the solid part of the starter's gear coincides. (guess maybe it works for you)
08.05.2020 18:25 # 8
iso307
Sir, your problem is as if the starter motor related coals are at the end point.
08.05.2020 18:25 # 9
mican69
a few people said that it might be caused by coal, it seems like this is general.
08.05.2020 18:25 # 10
kivanc
The first thing that comes to mind is coal. I had this problem in my 206. doing it while the coal is running out. it was never the last to press. But it would take a single press in between.
08.05.2020 18:25 # 11
mican69
thanks kivanc ...
08.05.2020 18:25 # 12
yunus26
I couldn't watch the video, but when you turn the anthem, if you hear the sound of missing die, I do not think about it, but I know that there is a lot of space for repairing something but the gear is worn ... 150 TL is paid for, already, respect for the workmanship ...
08.05.2020 18:25 # 13
mican69
When I turn the anthem, the sound is heard, the video understands you, but if the construction is a different problem, thank you to the people who replied that it is very difficult for me to have it here.
08.05.2020 18:25 # 14
mican69
I do not know the system exactly, but it has to be gear to transmit the rotational motion. It seems to me that some of the gear of the starter motor is worn. The starter 's gear may be operating when the solid part of it coincides. (guess maybe it works for you)
it was exactly as you explained it was caused by the starter gear.
08.05.2020 18:25 # 15
ByHack
Dear Professor / colleague; When I started, I couldn't hear something like kidnapping sound in the video. If you press the starter, a click sounds and if the starter motor does not start / rotate, the first contact is thermal coke or coal of the starter motor. Turn the key very, very slowly while pressing the starter, to check if there is a malfunction in the ignition thermal. So look for the key position where you hear that click sound Tongue If starter is a thermal problem, its price is around 40-50 TL (I know from your friend palio :) If it is not working, it is necessary to look at the coals, if there is a familiar master, the room will make 40-50 tlye (due to manual labor). it is necessary to look for a mechanical problem that may be a little more salty Smile Stay healthy ... byhacker 2014-04-24 00:33:12
