starting problem
08.05.2020 17:20 # 1
yener38
Hello everyone. ,,,, Let me tell you about the problem of the vehicle immediately. I need your help.
vehicle 2002 model 307 tript + lpg 110bin ..
I had no problems in the starter while the engine was cold
but when I start with the engine hot, it sometimes doesn't start and & nbsp; It sounds like a metallic cuvvv :). After trying a little bit, hard power works ..
Today, I did not work for 10 minutes. He worked as if he did not have any problems when he was cold.
08.05.2020 17:20 # 2
serkan719
flywheel gear is peeling off & nbsp;
or the part of the starter that comes forward and does not work. Take It Urgent.
08.05.2020 17:20 # 3
Bugra
it is probably related to the starter motor. it is good to have a look.
08.05.2020 17:20 # 4
jivang06
I think the problem of the gas pump will look at it and start and close without starting the starter 3 times, and if it does not improve, the gas pump will change.
08.05.2020 17:20 # 5
yener38
As I said, this problem only happens when the engine is hot.
08.05.2020 17:20 # 6
No sound will be heard from the starter motor.
08.05.2020 17:20 # 7
rakasan
the same problem happened to me my brother 206 2001 model bored the people so hard that they could not last and took me to the industry they said they missed the starter gear, I wanted to change it, I changed 3 repairmen :) no one dared to change the starter gear in a very bad place. Go to a car electrician right now, get master at work :) As I said, not every father does this :)
08.05.2020 17:20 # 8
rakasan
It doesn't matter when the engine is hot or cold, my brother does it sometimes when & nbsp; when he is hot, he does it when it's cold, but when he is usually hot ...
08.05.2020 17:20 # 9
acemi pecocu
[QUOTE = laedri] There will be no sound from the starter motor. If you suspect the pump, start the car directly at lpg. If it runs smoothly every time, it may be a result of the pump.
[/ QUOTE] Exactly when I make a long road in my car clicks was left I had a break on the road click says it doesn't work i read all the prayers i know i was working when ww wanted it they changed starter auto got rid of & nbsp;
