Starting but not working
04.06.2020 13:43 # 1
tokatli_2002
Hello friends, I have a peugout 206 sw 2004 model vehicle. In the first studies recently 3.4. It works at the starter, then there is no problem. The gasoline pump of the vehicle has changed, the spark plugs were renewed, the injection was clogged, and it was cleaned, my master, but there is still the same problem, he has the idea, I am very happy with the answers.
04.06.2020 15:10 # 2
First of all, welcome to us. My teacher, the pump that is attached to the supplier industry may still be the same problem. gasoline filter and gas pump pressure should be measured. If there is a lpg, it may be due to late work. If the membrane in the lpg regulator is broken, it causes gas to escape in the manifold and the fuel mixes, which causes the vehicle to start late.
05.06.2020 00:51 # 3
tokatli_2002
Thank you my master suggested to change the heat temperature sensor.
05.06.2020 02:07 # 4
muzzy35
I wonder if my brother Soner does this because the remote control battery is low, is it possible to recognize such a thing when the battery power is low after 2 3 attempts? By the way, brother get well soon, albeit in the smallest possibility, change the battery may be ridiculous, do not judge it &# 128514; &# 128514;
