Starting and Watering
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508
27.12.2021 11:55 # 1
SonerAK
Hello everyone ;
2014 I own a 1.6 ehdi auto6r. The car has been at 60 thousand km for 2 years and now we are at 250.xxx km. I have 2 problems since I bought it
1. The left rear side of the vehicle gets water under the floor. When pressed, it takes 2-3 seconds and works jerky. It keeps it fixed at 80 degrees in normal cruise, as if it fixes it to 90s when going up the ramp, but when I squeezed it hard on a steep ramp in summer, it fell back as if it saw the 95s. Is this normal?
Thank you in advance for your answers. Have a good day.
29.12.2021 10:26 # 2
Hello,,
1-Check the left rear taillight and trunk vents, sir. or you have to remove the trunk floor coverings and check the back. even tilt the rear seats and let someone get water from the outside, you can check it from the inside with a flashlight.
2- The temperature seems normal to me. but was the thermostat changed before or the vehicle was used without antifreeze.
Be careful with the 3-fuel filter, if it doesn't change for a long time, or even fake products are sold because it's original. don't start the starter right away when it's hot, wait a little longer and start a starter like that.
19.12.2022 16:25 # 3
nuaydog
Hello,
2012 508 auto6r access 205k km
I have the same starting problem.
The car works fine when it's cold.
But when the temperature is around 90 it works jerkily, shaking the car.
It seems like the car is shaking while it is stopping.
I took it to a master, he said it was because of the motor mounts.
I replaced them. but it still has the same problem when it's hot.
It doesn't do it all the time.
Another master said it could be caused by the flywheel. He said to use this shape until the pressure pad is finished.
The person I bought the vehicle from said that the flywheel was changed, but I still don't know the reason.
Did you find a solution?< /div>
