Starter tooth difference
08.05.2020 16:39 # 1
xpyhre
The 206 gti starter is said to have 11 teeth (12 volts). What happens if a 9 gear starter motor is normally fitted? Would you mind if any 11 gear starter motor is installed? Must I have 206 gti valeo Orginal starter motor? Does it have anything to do with the 2.0 engine? when I research it it writes 1.6 compatible 1.9 compatible 1.4 compatible starter motor. Which starter engine will be used for 2000 engine?
I would appreciate if they know about the subject, write comments, enjoyable forums ..
xpyhre 2012-03-17 01 : 37: 49
08.05.2020 16:39 # 2
I can search if you can send your vehicle's chassis number.
What is wrong with your mars engine?
koliva 2012-03-17 09:39:55
08.05.2020 16:39 # 3
xpyhre
the starter motor does not start, it must change ..
08.05.2020 16:39 # 4
I think your vehicle has a mars engine in the valeo D6RA model. To be sure, you need to look at your chassis number. Have you gone to repair it? Often there are problems in their brush. Have you tested whether this is happening?
08.05.2020 16:39 # 5
xpyhre
I am giving the chassis number .. XXXXXXXXXXXXXXXXX I made the repair again malfunctioned & nbsp; must have original valeoma? The starter motor mitsubishi that came out of me was how many teeth it has bothered you working with how many volts. Wouldn't there be any 11 gear 12 volt starter motor?
koliva 2012-03-18 05:59:31
08.05.2020 16:39 # 6
[QUOTE = xpyhre] I am giving the chassis number .. XXXXXXXXXXXXXX fixed it again failed & nbsp; must have original valeoma? The starter motor mitsubishi that came out of me was how many teeth it has bothered you working with how many volts. Wouldn't there be any 11 gear 12 volt starter motor?
In the Servicebox, there are many different ways of starting the starter motors. However, these are divided into two groups. The reference numbers of the groups are 5802.V7 and 5802.CW. You can see these models in the red and blue framed area on the right. I researched a little, the products of both classes are coming to the same door.
Star engines of both classes 12 Volt 9 dis. Its power is 0.85 kW. 55 degrees of freezing.
Easy to come.
& nbsp;
koliva 2012-03-18 06:12:22
08.05.2020 16:39 # 7
xpyhre
Thank you Koliva.
08.05.2020 16:39 # 8
[QUOTE = xpyhre] Thank you Koliva. [/ QUOTE]
You're welcome. Still, of course, as usual, apply the "kirk siz bic". Verify from a technical service or a master before receiving. I do not think it will be wrong, but it is useful to check "Wink"
koliva 2012-03-18 19:48:22
08.05.2020 16:39 # 9
xpyhre
The mars motors of both classes are 12 Volt 9 dis. Its power is 0.85 kW. The freezing point is 55 degrees ...................... & nbsp; Koliva features you call normal 206 starter motor. I asked one of the publishers that the 206 gti starter motor was different. By the way, I enter the chassis number from the servicebox, these starter motors come out as you said. for example D6G3 ///// and //// D6RA & nbsp; There is a model. This model is the same starter engine that comes out of my vehicle. but it writes for 1.6 vehicles. On the site where it was sold.
I asked the official seller below, said there are 9 teeth. And it shows this starter in the services box. This starter motor is identical in appearance to the starter motor that came out of 206 gti but. & Nbsp; There were 11 teeth, what would be the consequences if I put the same type on the defective starter motor? It was for 9 tooth 1.6 engines. What trouble can it be if the 2.0 engine is installed?
http://www.sahibinden.com/ilan/vasita-yedek-parca-otomobil-arazi-araci-pejo-206-dan-cikma-d3g6-model- numbered-valeo-dynamo-78832898 / detail
xpyhre 2012-04-30 21:45:46 < / edited>
