Starter Pressing Car Does Not Start :( Fuel Problem
08.05.2020 18:46 # 1
adiladil
307 1.6 Hdi 2006 model. when I turn the key, the starter starts but the car does not start. even if the vehicle stops downhill, the starter is pressing and the vehicle is running. I encounter this problem if it goes uphill. I wonder what could it be? respects.
08.05.2020 18:46 # 2
koray
The same thing happened to me, a piece of the pump inside it was broken, I added it to 70 TL a month ago, said the coal was burnt, as far as I remember.
08.05.2020 18:46 # 3
adiladil
[QUOTE = koray] the same thing happened to me, said a piece of the pump is broken, I put it to 70 TL a month ago, said the coal was burnt, as far as I remember. [/ QUOTE]
master, can you remember the name of the part, starter engine coal?
adiladil 2014-08-28 11:25:59
08.05.2020 18:46 # 4
Cyrus35
First of all, my brother is usually in the 206's, this is how the solution of your 307 is contaminated. The construction is simple. I changed it 2 or 3 times. amounts are replaced with sub-industry parts. You can get it installed in most industrial auto electricians, of course you have to detect the fault precisely in order not to waste time first. For this, close the windows when you get in the car, sit in the back seat, ask a friend to open the ignition to hear the seat, turn the ignition, when you hear a sound called zzzzz, the gas pump means the engine is solid, after making sure that you can make sure that you can make sure its solidity in this way. This is the part in the picture.
08.05.2020 18:46 # 5
Cyrus35
Soryyyy I pray that your vehicle's diesel engine diesel pump is not faulty, it is very costly and costly. It is not a construction, I guess by guessing, our masters in the forum know better. The diesel filter may be clogged, the hoses may have a malfunction, the dirty diesel may have caused it. The construction problem is solved in a short time. Disapprove
08.05.2020 18:46 # 6
adiladil
I also think that the vehicle was damaged while the vehicle had very little fuel.
08.05.2020 18:46 # 7
koray
charred brother
08.05.2020 18:46 # 8
koray
just like the master told me that. When gasoline is low, the coal cannot cool. And he said it is on fire. He changed it now works like a beet engine.
