Starter motor (Resolved)
08.05.2020 16:18 # 1
xpyhre
Hello, how can I remove the starter motor on the 206 gti vehicle from the vehicle's own engine,
I look from the bottom, I can't see from the top, I can't see from the top? If there are friends who know about it, I would be happy if they reply.
xpyhre 2011-12-02 17:45:19
08.05.2020 16:18 # 2
Kemanyak
Puffy part under intake manifold. You can only see the trigger. Master help is a must
08.05.2020 16:18 # 3
xpyhre
Thanks, teacher, but I am looking for the opportunity to disassemble it without the need for a master, because I can remove the starter motor and take it to the master.
08.05.2020 16:18 # 4
Kemanyak
It is dangerous with a jack. Go to the channel, you can handle it from the bottom, but you will have to remove the air filter part or something. If you have time and dexterity, you can. As I said, there are masters who can disassemble and repair without buying a lot of money.
08.05.2020 16:18 # 5
basrix
Do not forget to disassemble the negative terminal of the battery, you will burn the installation without removing the starter & nbsp;
