starter insurance
19.05.2021 16:49 # 1
laedri
hello my car citroen c4 1.6 HDI 2006 model vehicle 6 months ago the starter fuse was burnt out. 6 months later it burned again, I changed it again 40 days later it just burned out. Does anyone know why this fuse blows?
19.05.2021 23:27 # 2
talip206
It could be like this
A low amp fuse is installed before you. When it's lit, you're wearing the same value. It also burns because it is low again. Look at the booklet and see if it is at its original value.
If it is at the original value, there is a fault in the starter motor, it draws high amps or there is a short circuit. It also blows the fuse.
20.05.2021 18:46 # 3
laedri
the value written in the booklet is inserted
21.05.2021 11:47 # 4
talip206
Then either there is a sachet in the cable or the starter motor is troubled.
Go to any electrician and have the starter motor serviced. Let him change the starter while it is on and check the coals. They're already cleaning it up. They also check the cables.
