start stop battery
08.05.2020 21:16 # 1
qassim bey
greetings regards. The voltage measurement of this battery is 10 or so. The battery will expire in November 4 years. but start stop works just fine. the batteries say change immediately. I asked a skater to the master, why would he change the battery without the breakdown? what do you say?
08.05.2020 21:16 # 2
sozuak
The battery may die suddenly, even if it has a colored charge indicator on it. The batteries charge the battery with a high current for a certain period of time and find out if it has changed. There are a few things to know that most people don't know about them.
1- Batteries with charge indicator check whether they are charged according to the density of the electrolyte in them. According to the electrolyte, a battery that appears to be charged may suddenly fail to start. You cannot understand that the battery is intact by looking at that indicator.
2-Batteries are formed by combining 6 of each 2 volt cells.
a: Cells lose their surface area over time, which means their capacity is reduced. For example, when drawing 1 ampere, the voltage does not play, but when the starter motor draws 50-100Amper, they cannot give the current.
b: Lead intercellular connections become corroded over time. This line causes the voltage to collapse at high current since the line is serial to the whole circuit, and the high current drawn further weakens as it gets thinner, and the battery becomes open-circuit in an instant and does not give any voltage.
3- Although the batteries are completely neglected, over time, they convert the electrolyte into gas and release it. The electrolyte level cannot be controlled from the outside, but as it begins to fall below the cell plates, there is a loss of capacity and after a while they lose their capacity permanently as above.
A long time of 4 years. I recommend that you change your battery as soon as you will stay motionless on the road where you have never been. It is not clear when he will leave. In addition to the battery cost, it can also take the towing cost, but the worst thing is that you are on the road in an emergency. you can't measure it with money either.
