Start stop
08.05.2020 21:02 # 1
EnDy55
Good Friday everyone good forums. I have a 2012 model 308 sports vehicle. What I do is start stop operation. I took it to the authorized service, the whole system is running but the start stop is not engaged. The new battery is also altered but the situation has not changed. One last possibility is the possibility. How to activate the system back if left.
08.05.2020 21:02 # 2
First of all, welcome to us. What kind of operations were done in the service other than the battery, hodja? You have changed a battery because of the start - stop reasons. Also, electric or electronic operation was done to the vehicle afterwards sound system - such as exnon headlight etc. priority reasons
1-continuous short distance use
2-leaving the seat belt on all the time
3-battery (you have already replaced) I think it is a start-stop compatible battery.
08.05.2020 21:02 # 3
EnDy55
I mastered it. I changed the battery and used it for about a week. I measured the voltage of the battery. The battery remained constant at 12.5. The battery that installed the battery did not come to the battery. He said he had to start stop. He said he had to work on the 15 minutes, he used it for 20 minutes, but he did not work. He used it for a while. He said he had to work for a long distance. the voltage was 14.5. I left the car for 12 hours to charge the battery. The battery shows the battery fully charged and the battery charge is 14.5. I did not do anything, so I did not add cutting drills on the original one. Could this system disable the program by means of the program? endy55 2018-10-12 11:33:19
08.05.2020 21:02 # 4
if it is closed by peugeot original software hojam. If you go to the service and tell them, they will look at the settings of the vehicle. Possible service did not look at this, as you said, there is no other possibility because
