Star stop urgent please
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
24.08.2020 23:23 # 1
01iso
Greetings peugeot 308 2016 diesel automatic vehicle I have a star stop stop, but when I take my foot off the brake, the vehicle does not work, the screen does not work, start the vehicle to idle, it appears from the battery, it was said that the battery was replaced with the battery with star stop. I will go crazy and grateful if there are friends to help.
25.08.2020 11:40 # 2
First of all, welcome to us. My teacher, I checked the fault codes with the computer, the system may be giving an error. There may be a problem with the start stop brain.
25.08.2020 12:05 # 3
01iso
We found it nice, thank you, it has been connected to the computer many times, the error code is P1A92 49 and P1A93 U1334 86 P1A98 04 The vehicle works 4 times star stop but it does not work on the 5th pearl 58 When the electrician connected it to the computer, these errors did not occur ...
26.08.2020 18:21 # 4
[QUOTE = 01iso] We found it nice, thank you, it has been connected to the computer many times. Error code P1A92 49 and P1A93 U1334 86 It turns out to be P1A98 04. The vehicle works 4 times with a star stop but it does not work at the 5th pearl. QUOTE] P1A92 this teacher is a fault related to egr and dpf, other fault codes are caused by the problems in the alternator and socket pins. I think the sockets and cables should be checked properly. how many volts in the alternator while under load, etc. he gives.
26.08.2020 20:14 # 5
01iso
The last time the electrician was connected to the computer, this time it did not fail, but the problem continues, I wonder if we can turn off this star stop with software?
26.08.2020 20:18 # 6
01iso
My tool never gave any errors on the screen regarding egr and dpf ...
30.08.2020 19:57 # 7
01iso
Greetings, friends, I wonder if there are any friends on the European side to close the star stop with software? If so, can you please share their information? I wonder if there is no friend to help? 01iso2020-09-02 21:02:13
09.10.2020 20:38 # 8
01iso
Greetings peugeot 308 2016 diesel automatic vehicle friends, if the vehicle is in N position, friends who try to start the vehicle without pressing the brake, I will be glad to ask this, which is why a friend says that if the vehicle is working without pressing the brake in position N, the brake switch is out of order waiting for your answer ... running without braking ...
07.11.2020 19:50 # 9
347234
If there is seat belt silencer, disconnect it when ignition is on
24.06.2021 10:53 # 10
yavuzb
I'm going to revive the topic again, but I have a problem with start stop, I wanted it to proceed from the same issue.
I just bought my car, it's been 2 weeks and start stop was working. As you all know, when you stop at the lights, the green eco text appears on the screen. and the vehicle stops. Then it stopped working even though startstop was active. When I stop with the vehicle, the eco text appears, flashes 3 times and disappears. The vehicle continues to run.
I suspected directly from the battery on 2014 orj. There was a battery. I had it measured. 13v output is a good value.
Seat belt fastened
air conditioner off
everything seems normal. What is the problem? I could not understand.
I would appreciate if friends who have knowledge on this subject could help.
07.05.2022 17:26 # 11
347234
Hello 2016 bluehdi eat6 in my car, just like yours, P AND N works without pressing the brake. I went to the service to see if it's a problem, they said it may not be, they say they have it in 2017 or 2018. But even the authorized service is not sure.
09.05.2022 09:06 # 12
actually it shouldn't work. I think it's like a software issue. Security casualties are a troubling situation. If necessary, send an e-mail to the authorized service or Peugeot Turkey, they should ask the center of France, there should not be such an uninformed service.
09.05.2022 09:29 # 13
347234
Thank you for your interest and answer, but in most forms, they wrote that 2016 works for automatics without pressing the brake, but still need to send an e-mail and clarify.
