Stand back in the air
08.05.2020 15:26 # 1
fTh206
arkdşlar I have 206 when I pull it uphill, it stands in the air, what do I have to do or what should I do with all 206's?
08.05.2020 15:26 # 2
this is normal something bro a situation related to the vehicle's rear suspension structure. If there is a downhill slope, the rear of the vehicle cocks down. What matters is how it stands on the flat floor ...
For example, if you pull the handbrake while the vehicle is going forward, the back will be lowered, if you pull the handbrake backwards, the back will rise up ...
By the way, if you are not in your profile where are you from Istanbul?
the cecol 2011-05-19 14:02:25
08.05.2020 15:26 # 3
fTh206
[QUOTE = CeCoLi] this is something normal bro. a situation related to the vehicle's rear suspension structure. If there is a downhill slope, the rear of the vehicle cocks down. What matters is how it stands on the flat floor ...
[/ QUOTE] but mine is on a straight road as if I was looking a bit in the air, I am looking at the other 206, is it normal? (I forgot to write istnbl fatih, sorry there)
08.05.2020 15:26 # 4
the back of these 206s do not hold each other. some look like storks. some are going to take it. There is no standard as well :)) I am not talking about those who have been inferior.
Also, where are you on the conqueror?
08.05.2020 15:26 # 5
ose
As all the vehicles say, the friend, including buses, whose nose or back gets up on the slopes. If you say straight road, pull the vehicle to a flat place, put it in hand, take the handbrake down, take a picture from the sides, put it in the forum, let's see it.
08.05.2020 15:26 # 6
fTh206
[QUOTE = cecol of]
Also, where are you in the conqueror? [/ QUOTE] you are right, there is 206 in the arc, I do not have a solution even if it is low on the steep slope. I do not know what kdr is right.
>>> conqueror corpse <<<
08.05.2020 15:26 # 7
fTh206
[QUOTE = kankam_743] All vehicles are uphill on slopes, as the friend says, including buses that have his nose or back in the air. If you say straight road, pull the vehicle to a flat place, put it in hand, take the handbrake down, take a picture from the side, put it on the forum, let's see if it is going to happen to you.
08.05.2020 15:26 # 8
already peeling at friend. Park on the gear without handbraking in one place. Take a picture from 2 sides to see exactly on the other hand, let's see here together. I think it will be a very problem if it doesn't happen to me.
We have 3 more members that come to mind on the conqueror. you are 4 too. I am also in capa with my colonel. why don't you come to meet etc?
the cecol 2011-05-19 14:20:50
08.05.2020 15:26 # 9
eren8er
[QUOTE = fTh1234] [QUOTE = CeCoLi]
no way :)
08.05.2020 15:26 # 10
fTh206
I could not come because there was not much time, but now I try to come somehow summer came :))
the cecol 2011-05-19 14:40:44
08.05.2020 15:26 # 11
volkan_uysal
Sırıtma
[QUOTE = cecol of]
Also, where are you on the conqueror? [/ QUOTE]
08.05.2020 15:26 # 12
Do you keep the ramp down for 15 days ?? Sırıtma very clever :))
08.05.2020 15:26 # 13
what is that, uh :)) giant picture like :) :) you will put 800x600 ... any picture of how to put a picture if you go inside a forum it writes above ... how to add a picture to the site
I also need a picture of the car from the side, my beautiful brother. what unwritten aw ??? incomprehensible back
08.05.2020 15:26 # 14
fTh206
unfortunately it's not on the side but i put it in the evening i pull it when i go home
08.05.2020 15:26 # 15
I remove the picture because the size is very large, you add a new one. You have to shoot while you're on the ground. the vehicle will be seen exactly on the side. and if you can shoot from a distance, its speed will be seen more clearly.
08.05.2020 15:26 # 16
ose
a kankam_743 2011-05-22 01:00:49
08.05.2020 15:26 # 17
Melih
mrb will take me back to the car too, especially the slope is down, I asked the master, he said it is normal, even the rearview mirror does not show the back.
