stall
08.05.2020 14:12 # 1
serFBdar
The idle of my 1998 model 306 car is constantly playing on the gas and is stating when it turns the steering wheel. It is a miracle to keep the car running when the car is cold and in short maneuvers. I just bought the car and I am scratching. I went to the service, they did not connect to the computer, but they said the idler adjuster was broken. Its price is 417 TL. It was very expensive for me. What should I do? it is said to be cleaned but not guaranteed. In a special service, it was said that even if the idler adjuster changes, it may not improve. what can you suggest to me
08.05.2020 14:12 # 2
hasimayaz
the butterfly will be cleaned, use it for a while and if it returns to the old one after a while, the idling valve should change .. butterfly cleaning 15 minutes work .. detailed information for this process is below:
They exaggerated the price for the idle valve .. You can get information about this subject from the link below.
hasimayaz 2010-03-23 22:26:19
08.05.2020 14:12 # 3
serFBdar
THE PRICE OF THE ROLINE EVERYTHING HAS BEEN DIFFERENT. They entered this service with the engine number and gave this figure. IF THIS PRICE IS NOT CORRECT, YOU CAN GIVE INFORMATION WHAT IS RIGHT.
08.05.2020 14:12 # 4
serFBdar
IT DOES NOT HAVE TO RELEASE WHEN THIS ROLETTE IS FAILED AND CONNECTED TO THE COMPUTER. WHY WE GO TO THE TRIAL FAILURE.
08.05.2020 14:12 # 5
Kemal
First of all, writing with capital letters means shouting in the forum rules :) Sister first clean the idle adjustment valve and throat throttle, then reduce the idle of the vehicle, adjust it nicely, then set the LPG to 35 degrees when you format the LPG. I bought the valve but it was not necessary, I bought 235 TL
