STACKING AND STORAGE OF TIRES
Homepage » PEUGEOT MODIFIED PLATFORM » General
08.05.2020 14:02 # 1
hasimayaz
Storing tires between two seasons
Tires should be stocked as specified:
  • In a ventilated, dry and warm place and not exposed to direct sunlight and bad weather conditions
  • Away from any chemical, solvent or hydrocarbide that could damage natural rubber.
  • Away from any material that can penetrate into rubber (metal tips, wood,…)
  • Unless the tires are mounted on the rim and inflated, they should not be stored stacked for a long time. Tires should not be crushed under other objects.
  • It should be avoided that there are any flammable or combustible material, spark or any material (battery chargers) that may cause electric discharge.
  • It is recommended to use protective gloves for stacking the tires.
08.05.2020 14:02 # 2
I do not know these things, thank you my brother.
08.05.2020 14:02 # 3
Emin
Yes, it was a good information, I am hearing it for the first time.
08.05.2020 14:02 # 4
HakanGokdemir
Eee Haşim started preparing for summer, thanks for sharing ...
