Squeezes 307
08.05.2020 20:03 # 1
brkhkn
my friends car 2004 model 307
vehicle; hot cold doesn't matter. It does not switch to LPG anyway.
When it starts, the motor runs at an irregular speed as if it would stop.
When he gases lightly with his feet, he will recover in a few seconds.
but if I stop and run it again it feels like it is drowning again.
As I said, it does it only on the first run. when it gives a little gas, it improves immediately.
Why does anyone have any information like that?
brkhkn 2016-12-02 16:26:38
08.05.2020 20:03 # 2
esstel
could be a petrol pump ... at least a quarter tank full ...
08.05.2020 20:03 # 3
fætih
If there is lpg, check the regulator. look at the gas pump.
08.05.2020 20:03 # 4
palet
Turn the ignition on before starting start while starting the vehicle. Press the ignition after the petrol needle is activated. The time between opening the ignition and pressing the ignition will only press the petrol pipes of your vehicle's petrol pipes, which you have stopped using the gas pump LPG. LPG gas stop valve should also be checked. If LPG leaks into the LPG gas cutter cylinders while the vehicle is running on gasoline, both gasoline and LPG can go erratically as they will go to the cylinder at the first start.
