squeaking sound from steering wheel
22.05.2021 18:04 # 1
furkan0638
Hello. I have the problem for 1 week. When I turn the steering wheel to the right or left, there is a sound like a door squeak, and the same squeak continues when I enter the pits. There is no rattling sound in the pits, just the same squeak when I turn it left and right. Can anyone help if anyone has had this problem before?
27.05.2021 09:05 # 2
Hello, my teacher, it is a situation with a bleeding from the tie rod end, the rod shaft or the z rods.
06.06.2021 20:32 # 3
BedirXan
I have the same problem. It squeaks when I turn it all the way around. Is it also related to the rods for me? No, is it related to the steering wheel?
11.06.2021 10:18 # 4
furkan0638
problem solved. When I explained the problem, the master poured oil into the tie rod head or the axle bellows with the syringe, the problem was solved. I think this problem will recur in the near future, it would be best to change the part.
13.06.2021 08:44 # 5
Sail
Did you change parts?
