Squeaking Sound
08.05.2020 19:49 # 1
Poyraz61
Friends, maybe a lot of topics have been opened about this subject but I wanted to open it again. Because it's a little different.
My car starts every morning without any trouble, but after driving half an hour after the car, especially if the bidet is hot, squeaking noise comes from the front when the air passes through the bumps or when braking, stopping or taking off. Like a creak of doors. I took it to the master, said the front teams have no problem. I wonder why there are friends who have intellectual knowledge experience.
Good markets
08.05.2020 19:49 # 2
akk0212
can be from anti-roll bar tires
08.05.2020 19:49 # 3
gergerli
I had 206, I had the same problem, I went to the industry, a master syringe put the hydraulic oil under the wheel and squeezed it to somewhere, then he made it right and left with the steering wheel, there was no sound left, my teacher said it would handle you, if it sounds more, let's change that part 50-60 lira but I had sold the car without knowing if the sound had been heard.
08.05.2020 19:49 # 4
Poyraz61
I will go too, I will adjust my teacher.
08.05.2020 19:49 # 5
samet206
In front team problems, the squeaking sound usually comes from the swings.
08.05.2020 19:49 # 6
Ahmetaltan
I had the same problem. There is a movable joint on the part of the swings, which is close to the wheel part. With the syringe, you press the oil and remove the sound temporarily. But after a while it will make a sound again. I recommend you to completely overhaul the front set.
08.05.2020 19:49 # 7
Adem Kurtuldu
The squeak might want a front-end tool.
