Squeak when shifting
08.05.2020 20:37 # 1
Sabanoz
Hi guys. There is the 2009 model 207. A semi-automatic (robotic) creaking shifts come up like a spring sound. Do you think there is a malfunction of the rhythmic system or is it normal? I am waiting for your comments from friends who use it. If it's a problem, how is this repaired? Thank you for your comments in advance.
08.05.2020 20:37 # 2
Hello, hello. use but I did not hear a sound like you said so obviously when shifting gears. I also want to ask, is it a sound coming from the gear lever when you are moving first, or a sound that comes in gear changes while the vehicle is in motion?
08.05.2020 20:37 # 3
Sabanoz
It's not a sound coming from the arm. It comes from the robotic system in the engine part. You know, when you press the pedal while the clutch is on the finished vehicle, there will be a squeak like it. It takes off with every gear change. It does not come out while walking, it only happens in gear changes. When I asked the service, they said that it will be a problem with the decrease in the fat in the robotic part over time. I wonder how much it costs to repair or something.
08.05.2020 20:37 # 4
uzunca961
I haven't lived yet, but the oil comes to mind as the service says. I wonder if the transmission oil is missing, maybe he can
08.05.2020 20:37 # 5
uzunca961
In how many kms of vehicle has gearbox oil been added before?
08.05.2020 20:37 # 6
Sabanoz
I have been in 2 months since 107 thousand and now I will look at everything next week, I hope everything will not be bad. Thank you.
