"Squeak" sound when first running 308 1.6 vti
08.05.2020 21:14 # 1
Eskibonus
Hello everyone,
My vehicle is 308 1.6 vti automatic gasoline. When I don't use it for a long time (for example, from evening to morning), there is a "squeaking" sound on the first run. I just bought the vehicle (it's been 3 weeks) and took it to two masters, both of them said the chain sound. There was nothing to be afraid of. I also had 10000 maintenance. The master I had made examined the vehicle in detail. He said that the vehicle was in good condition. I showed the boredom to his cat and said normal. After the engine stops, the oil is drained and the chain, which is oil-free, made a sound in the first run. When he worked for 5 - 10 minutes, the voice goes away. Both masters said the same. It also happens as they say, the sound stops after 5 - 10 minutes. So when the chain is lubricated.
Is there a similar situation in the vehicles you use, or are the masters arguing?
Thank you very much in advance...
08.05.2020 21:14 # 2
Hello and welcome to us. I wish you to use your vehicle without any accident, good luck. Just like the masters said, my teacher has the same sound in my vehicle, even my friend has an i20 diesel room chain with a chain. Do not delay engine oil changes and use 5w / 30 oil.
08.05.2020 21:14 # 3
Eskibonus
Thank you very much for your answer ... I went on the suggestions of my friends to both masters, but still it gets stuck in the mind of the person. The master who took care also put 5 30 oils and told me not to put another one on top of it. Thanks again. May Allah avoid everyone from accident.
08.05.2020 21:14 # 4
you're welcome teacher
