Squeak Noise From Gear Stick
08.05.2020 20:12 # 1
Eyup B.
Hello friends
I noticed today when I shift from gearshift to 1st gear and from 1st gear to 2nd gear, there is sound, I show the video below to know the type of sound.
So much in this video, but not so much, and if you press it to the left, you hear it when you push it slightly outside, you do not hear it on the road (already, engine sound, insulating :))
IS THE PROBLEM BIG? HOW CAN IT BE SOLVED?
VIDEO REPRESENTATION.
[TUBE] ysswlbm_lgm [/ TUBE]
08.05.2020 20:12 # 2
ozgurtc
Gear lever bearing bush rubber rub-like sound, lift the gearshift and sound source can be seen, lithium grease may be the solution.
If there is no problem going into gear, there may be a non-critical malfunction yet.
08.05.2020 20:12 # 3
If there is no shortage of gear shifts, check the gear ropes and gearbox, firstly remove the gear bellows and tighten wd40 to the bottom of the gear under my teacher.
08.05.2020 20:12 # 4
Eyup B.
Sometimes it happens sometimes it doesn't, but after all. and there is only sound. the gear shift can be stiff at first when the weather is cold, but it is hard to shift, so I have no complaints
