Squeak heard during push / pull clutch pedal
08.05.2020 20:11 # 1
erbilist
Hello friends,
I can describe the problem as follows.
When the vehicle is cold, the clutch pedal is like cotton. There is no squeaking during point-and-shoot. Everything is as it should be. However, when I travel 5-6 km in the city, there is a small amount of hardening in the clutch and an annoying squeaking sound during the push / pull.
Vehicle: 2004 Peugeot 307 1.4 HDI XR
I changed my clutch pressure pad set at 140.000km. The vehicle is now at 170,000km.
There was also this problem before the pressure pad set changed. After the change, I was comfortable about 4000km. In 144,000, when the problem came back, I went to the master. My master lifted the car on the fiber and lubricated somewhere. I think clutch fork bushing or ball. (Correct it if I pronounced it wrong. Whatever its name is now ...) So the voice was cut off again. Until when? Until about 4000km of road.
As a result; I bought this vehicle at 90.000km and I have never had this complaint until 135.000km.
I don't understand which piece is saying "you forgot me, you should have changed me too". but I want whatever needs to be done for the permanent solution of the problem.
I look forward to the suggestions of valuable forums, who are struggling with this problem and victorious or have an idea for a solution.
erbilist 2017-02-10 02:34:12
08.05.2020 20:11 # 2
I think the problem is probably in this piece
08.05.2020 20:11 # 3
erbilist
Master, I changed this piece along with the press pad. I can clearly observe that the sound does not come from the fork during the push / pull clutch. The sound comes from somewhere below.
My master lifted the car on the fiber, opened the engine guard bar and lubricated it. I think there is another set of hardware related to the clutch assembly. Bush, ball, tension wire etc. Whatever the name is ... My trouble is there. Disapprove
08.05.2020 20:11 # 4
I wish it would be better if you could take a photo. I wonder now
