Squeak from behind
08.05.2020 20:40 # 1
GiTaRRa42
With my vehicle while driving, it sounds like a squeak, friends. What is the reason for this?
08.05.2020 20:40 # 2
pusutr
shock absorber can be wedges or front layout.
08.05.2020 20:40 # 3
Kocak
[QUOTE = pusutr] can be shock absorber pads or front layout.
+1
Kocak 2017-12-02 15:29:16
08.05.2020 20:40 # 4
GiTaRRa42
It is not tidy but the forecast comes from the right rear tire.
08.05.2020 20:40 # 5
pusutr
Check the spare wheel. Inflate the wheel and put something to stop the friction between the tire and the iron. cloth, for example. Of course if not shock absorbers.
08.05.2020 20:40 # 6
RP393
Go behind the vehicle, look at the rear wheels from afar. If a tire or both are pushed in as if a camber kit has been built, the torsion bearings are gone and the torsion shaft is worn. It sounds like a creak of a cot, especially on a bad road.
No, if it shoots bluntly when yawning, one or four of the torsion cartridges are broken and it is less costly.
08.05.2020 20:40 # 7
GiTaRRa42
There is no image right on the ice as camber is made, I sit in the car park, I sit in the trunk, and the sound sounds hard, I clicked the car, I raised it, I took a look at the amartisors and try it in order.
08.05.2020 20:40 # 8
RP393
[QUOTE = GiTaRRa42] There is no right image in the car like camber made, I sit in the car park, I sit in the trunk, and the sound is hard, I clicked, the car was pressed, I took a look at the amortisors and try it again, I hope we do not want it any more, I hope we have the same sound again.
The shock absorber does not break down easily, they probably have no problem. Does this sound come to the bottom when you sit down and press the car, or does it come down and down
08.05.2020 20:40 # 9
GiTaRRa42
When I get in the car, there is a click, I open the tailgate and sit in the trunk, I get that sound hard, I shake the car, I don't get that sound
08.05.2020 20:40 # 10
GiTaRRa42
I just inserted it completely a bit ago, put it blank, I continued to get the same sound again, and we eliminated it.
08.05.2020 20:40 # 11
GiTaRRa42
With my car while driving, it sounds like a creaking click, friends. What is the reason for this?
3 problems, 2 exhausters and 1 normal master could not solve our problem.
I picked up the car in a high place, my friend started shaking as I could get under it, but I got the sound small in treble and I knew it was coming from the amartisors, I knew that I had no problem with the bellows on the inside and I had a spray oil on the inside.
08.05.2020 20:40 # 12
onlycihan
I also sound like a high pitched sound when the vehicle flexes a little.
08.05.2020 20:40 # 13
Adem Kurtuldu
There may be a spare wheel iron, but look at it, but if there is a shot or something, it is probably torsion or ammunition.
08.05.2020 20:40 # 14
onlycihan
I checked the spare wheel, not like knocking, it leaves and leaves like a budgerigar.
08.05.2020 20:40 # 15
pusutr
[QUOTE = onlycihan] I checked the spare wheel, not like knocking, it leaves and leaves like a budgerigar not constantly, I don't worry too much but I like to use the vehicle silently [/ QUOTE]
It will make this sound if the swing of the swing blows and when it gets wet. If the shock absorber pads are worn, this will make a sound. So the sounds you say are related to the plastic parts. concentrate on plastic parts.
