Spray paint
08.05.2020 17:01 # 1
yenice
Greetings. Would it be healthy to paint tape, air conditioning frame and inner door opening places on the front console with spray paint? Does it spill? Do we have to apply a primer?
08.05.2020 17:01 # 2
istanbullu_3886
I painted the bar on the rear trunk release lever, peeling like a spray paint, soon afterwards
08.05.2020 17:01 # 3
I will also paint the upper luggage line on my 307 SW vehicle soon. As much as I searched, I needed a primer. Then paint and varnish.
08.05.2020 17:01 # 4
yenice
I asked the hairdresser friend recently. He said he will come to the wholesaler on Monday, then I will call you. talked about a kind of spray paint. I don't know if there is a different contribution. He has a price of 30 TL, he said, expensive than other spray paints. What kind of thing will I look at on Monday?
Doesn't it actually differ from outside and inside? because it is constantly exposed to moisture, heat and water outside.
08.05.2020 17:01 # 5
yenice
http://www.hepsiburada.com/liste/automix-peugeot-206-1001-0110-arasi-alumiyum-kaplama-seti/productdetails.aspx?productıd=otsv1001628007802&categoryıd=259374&sku=otsv1001628007802#gorsel
Does anyone use this? How is the color of it? actually 70 Lira is suitable. spray paint primer varnish will find the same money. replacing it will be more costly if it is not done properly.
08.05.2020 17:01 # 6
mev347
I painted the place you said last weeks. I had spray paint in auto painter, bidet varnish. First I sanded the console with fine sandpaper, then I applied the paint a few 15 minutes apart. Then I took the varnish a few hours later. the result is very nice. But the important thing is to be able to discard the paint properly, or it makes no sense.
08.05.2020 17:01 # 7
inandugcar
First, throw the plastic primer you will get from the auto painters to the floor that you have prepared with 2000 grad sandpaper. Apply the coat you have prepared in the auto painters as a 2-fold coat without waiting for it to dry for a very long time. Shedding, peeling, etc. you can be sure that you will never live ...
