SPORTS SPRING INSTALLATION
08.05.2020 18:53 # 1
Buspiron
Hello friends, I would like to have a sports spring application on my vehicle. It was a vehicle that I drive with my family every now and as a result of the 5 cm sports spring, I thought it would be too much to wear a 3.5 spring bow, because I thought that my driving pleasure would be lost and it would force me more.
Let's come when I do market research on the internet:
http://urun.gittigidiyor.com/otomobil-motor-aksesuar/kargosuz-peugeot-306-spor-yay-yumusak-hediyeli-127703114?gclid=cjwkeaiahcgjbrdot_fjjtpkrgssjacnyh76mbu3xabs3qm43gvkzkgzvejl5j7xx2volnjcedqvuxocsn7w_wcb&mpch=ads&scxid=14489-145818-2357-0
Products worth 99 TL
http://urun.gittigidiyor.com/otomobil-motor-aksesuar/pejo-spor-yay-seti-peugeot-306-apexi-3-5-cm-126912817
I have encountered products worth 110 TL, of course there are more expensive models but I want something suitable
Come on, after I bought the product, I do not need rot balancing again after I have it exploded with the assembly, I do not know the pros and cons .
08.05.2020 18:53 # 2
tolga.onal
I couldn't find a place that wears under 200 lira in Istanbul, after I got it for 307, it is necessary to go into the rot setting. It was something around 20 lira.
08.05.2020 18:53 # 3
herry
If you put 3.5 bows, the height does not change much, if you put 5, your vehicle will only be lowered. it may be necessary to play with the torsion setting on the back and bring it closer to the ground when a bow is attached to the front. I am using fk bow. You can buy an original 5cm bow for a figure of 100 TL. they request a fee of 100 TL for the assembly of this. As the tolga says, it is useful to make a adjustment at the post-rot balancer. They take it for 20-30 TL. If the back of the car is too high relative to the front, it is also necessary to reduce the torsion down, it is not inserted or inserted in any part while the torsion stops. there is only workmanship, they demand a fee in it. If you make the plateau torsion in the same place, they will make a figure like 150 TL, but if you go another day for torsion, they can get 100, I don't know it exactly.
This dropping is such a thing, and if your goal is to drop it a bit, I recommend 5 cm. If you wear 3.5 and stay in the air, you may have to spend the same costs and charges within 5 cm.
