Sports bow selection
08.05.2020 14:56 # 1
salih_guven
Hi friends, I would like to have my sports quicksilver 106 fitted with a sports bow. Can I get brand advice for the bow from experienced friends ??? They also said that the original springs were cut by laser, they made friends which method would you recommend .... Thanks, good forums to all ... :)))
08.05.2020 14:56 # 2
GokhaN
I have used eibach in my old 106 quikim. I do not recommend cut springs very dangerous.
08.05.2020 14:56 # 3
FTH
Spring cutting I cut the front tool went completely sports spring 160 is not worth cutting between 180 TL.
08.05.2020 14:56 # 4
salih_guven
I hesitated, thank you very much Gökhan ... :) If I ask for one more thing, does the proximity to the ground increase as the millimeter rises? how many mm. do you recommend
08.05.2020 14:56 # 5
GokhaN
[QUOTE = salih_guven] I was hesitant too, thank you very much Gökhan ... :) If I ask for one more thing, does the proximity to the ground increase as the millimeter rises? how many mm. do you recommend? [/ QUOTE]
Since the engine of the cars is light, 3.5 does not help much. If you wear it, it will not drop as much as gti, but it is ideal for quik. As the mm rises, it gets closer to the ground.
08.05.2020 14:56 # 6
Aytac
In my opinion, I would recommend my ideal friend, take 4, my friend, neither will I get too much or too high. )
08.05.2020 14:56 # 7
salih_guven
thank you very much for informing friends ... :))
08.05.2020 14:56 # 8
ozaannn
buy eibach dont give up cutting the original spring is very dangerous also the car will not stretch if you cut the original
08.05.2020 14:56 # 9
Ahmet 9716
Which brand bow do you recommend for 106? Let's get something good, right?
08.05.2020 14:56 # 10
herry
We are always breathing, we are breathing, every part of the forum is filled with the topic of spring. If you do not think of your own life, think of the lives of others, do not do illegal works such as running bow cutting spring heating and running from 3 to 5. it is not clear what will happen. one uses it for 10 years, no one can use it. In the first week of the other one will be broken. your life is over. Get the original sports bow eibach is good, expensive. I'm using fk, I'm glad, the price is ideal.
08.05.2020 14:56 # 11
outlaw
I HAVE BEEN USING FK FOR 3.5 YEARS AND I HIGHLY SATISFIED THAT I DO NOT THINK THAT IT IS EIBACH ORIGINAL IN THE MARKET ..
If we come to the sub-team event, I haven't had the sub-team done for 3.5 years depending on your use.
IF WE MEET THE MEASUREMENT, YOU WILL BE A CHANGE OF 5 CM WATCH THE ENVIRONMENTAL 3.5 NO CHANGE ...
08.05.2020 14:56 # 12
rizeli_53
I don't understand the cutting issue, how do they trust and do it. The son of a human has to go out of his own way. Would the leg of a person be both like the old one? Of course, I think the cutting spring looks like this. my personal opinion ......
