Sports bow for 206
08.05.2020 13:57 # 1
beddri
I want to buy a sports spiral for 206, but I think when 40mm passes, it is necessary to change the suspension, and these sets are sold for 2 limi.
Thanks to the friends who commented in advance ...
08.05.2020 13:57 # 2
sinan-s
You can attach 2 spirals on the pejos ... because the backs are torsioned. So 2 pieces of bow is enough.
08.05.2020 13:57 # 3
hasimayaz
[QUOTE = beddri] I want to buy a sports spiral for 206 but I think it is necessary to change the suspension when 40 mm passes. This is true and these sets are sold for 2 limi.
If you look at the original Bedri, you have to replace the shock absorbers in any spring change. Because the movement distance of the shock absorber is shortened. So you should use the appropriate shock absorber. But 3.5 cm. Original shock absorbers work until. only life is a little shorter.
There is a torsion suspension on the back. The torsion setting needs to be reduced.
The articles in the links will enlighten you on the subject.
hasimayaz 2008-09-26 10:40:47
08.05.2020 13:57 # 4
I have a friend, I have a 5cm bow, 2 sets of one side, 2 pieces of clean water like zero, I can sell it if you want.
08.05.2020 13:57 # 5
I have an eibach 3.5 cm bow. Let's talk if you want
08.05.2020 13:57 # 6
beddri
What is the price of bidet you have used taner bey nekard?
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
