sports bow
08.05.2020 18:07 # 1
pegasuss_35
2001 model 1.6 4-door 206 I put 16 inch 195 4516 tires and wheels on my car, we dropped ten spirals, the car image was nice, the only suspension event went to zero and the image I want is beautiful, also make a suspension. If I bought a sports spiral, this event will be corrected. I should wear 3.5 cm or 5 cm spiral. If I wear a 5 cm sports bow, the original amatisors will work. I want help. pegasuss_35 2013-12-08 02:45:30
08.05.2020 18:07 # 2
Alicilik
You can never get the original comfort in its original form.
The event that will happen when you put on a sports spring is the increased load on the shock absorbers. Sports springs are not softer than the original. If it is soft, even if you pass over the gravel, it rubs on the hood.
I got into the car of my friend who used 5cm einbach bow and kumho ecsta 195/45/16. I obviously didn't feel gram suspension after my stock 206. So I still get 175/65/14 stuck.
08.05.2020 18:07 # 3
pegasuss_35
It may be that we are hitting the originals by hitting the originals. Could it be better if we use 3.5 cm sports bows?
08.05.2020 18:07 # 4
Alicilik
[QUOTE = pegasuss_35] It may be that we are hitting the originals by dropping the originals. Could it not be better if we have a 3.5 cm sports bow trap [/ QUOTE]
3.5 does not lower the mast you call it, but the 30mm room does not add any meaning visually
I would recommend 50mm but forget the comfort with just a spring change without a coil.
08.05.2020 18:07 # 5
pegasuss_35
Sorry what you call a coil, I'm a little bit too sorry, it's in my dreams now
08.05.2020 18:07 # 6
Alicilik
Coil Over Kit
The spring and shock absorber are used together to add sports driving pleasure to the suspension. The load distribution is equally distributed like the original, but it does not retain the original in terms of hardness. There are many brands in the market, but you need to find them from abroad on the basis of quality. Bursa in Turkey and two in a company engaged in at Izmit.
Air Ride Kit
Fully air assisted suspension kit. In addition to the comfort, you can intervene in the height of the vehicle with the air tubes that you will put extra. The cost is cold, but there are also those who do TR.
08.05.2020 18:07 # 7
pegasuss_35
So you say back to the original.
08.05.2020 18:07 # 8
Alicilik
[QUOTE = pegasuss_35] So you say back to the original, 35mm spring, we don't spend a lot of money then [/ QUOTE]
Obviously, the 35mm 206 is not obvious to the eye.
08.05.2020 18:07 # 9
pegasuss_35
But if I took the original spring and put it 35mm spring, wouldn't it be more logical?
08.05.2020 18:07 # 10
pegasuss_35
By the way, thank you for your help.
08.05.2020 18:07 # 11
Alicilik
You're welcome.
As far as I know, the original spring is more expensive. 35mm kit can be preferred.
