Sport Bow Selection?
08.05.2020 17:59 # 1
allpastclear
FRIENDS BEFORE 206 ABOUT MY SINGLE DOOR I HAVE RECEIVED YOUR IDEAS UNDER THE STOP SELECTION TITLE AND SOLD MY AGAIN 206 Big smile THIS TIME 4-DOOR FELINE RC WHEELS VS EVERYTHING BUT I WANT TO FALL THE VEHICLE HIGH, THERE ARE THE SPRING BRAND KNOWLEDGE AND I NEED TO HAVE THESE EXPERIENCES THAT I HAVE THERE ...
08.05.2020 17:59 # 2
5 drops too much 3 or 3.5. They say Eicbach very well as a brand.
08.05.2020 17:59 # 3
TuNeR_32
17 inches. If you are using a rim, you should wear a 5 cm spring. Also, since the vehicle is 1.6, it will not drop 3.5 cm. Again, it will be like the original. If you want 5 cm, I have it.
08.05.2020 17:59 # 4
Barut
I have the same model on the same rim, I have installed an ebach of 5, the ideal came, the engine does not come down as it is small.
08.05.2020 17:59 # 5
huseyinsengonul
I use 5 in 106 quik, ideally, stop, if you pay attention, the problem will not cause you trouble
08.05.2020 17:59 # 6
allpastclear
[QUOTE = TuNeR_32] 17 inches. If you are using a rim, you should wear a 5 cm spring. Also, since the vehicle is 1.6, it will not drop 3.5%. If you want 5 cm, I will send it to 100 TL. I have not rubbed the gold at all, but this time I want to drive everywhere without paying attention, since my vehicle is 120 horsepower, I cannot come to slow down in the smallest thing :)
08.05.2020 17:59 # 7
allpastclear
[QUOTE = Red dream] I have the same model on the same rim, I have installed 5 ebach ideal, it does not come down because the engine is small. Smile
08.05.2020 17:59 # 8
allpastclear
[QUOTE = dogan106] 5 drop too much 3 or 3.5. They say Eicbach very well as a brand. [/ QUOTE] thanks for the information you provided Smile
08.05.2020 17:59 # 9
allpastclear
[QUOTE = huseyinsengonul] I use 5 in 106 quik, ideally, stop, if you pay attention, the problem will not cause you trouble. the tactics of gold is that if the front is a little higher, it does not crash, and when it is too low, the vehicle becomes very hard. I want it to be soft. Smile
08.05.2020 17:59 # 10
Barut
[QUOTE = allpastclear] [QUOTE = Red dream] I have the same model on the same rim, I installed the 5 ebach, it came ideal, the engine does not go down because it is small, my advice is to buy 5. I'm glad Smile [/ QUOTE] Adding image is causing some error.
Red dream 2013-10-20 01:40:28
08.05.2020 17:59 # 11
allpastclear
[QUOTE = Red dream] [QUOTE = allpastclear] [QUOTE = Red dream] I have the same model on the same rim, I installed 5 ebach ideally, the engine does not come down because it is small, my vehicle is recommended to buy 5. [/ QUOTE] first of all thank you I would be very happy if I could see the photo of your car Smile [/ QUOTE] Adding image is causing some error.
[/ QUOTE] it would be nice to see it, but thank you enough
