Spontaneous flashing of headlights
08.05.2020 20:53 # 1
Aysinsa
Hello friends,
About two hours ago, when the weather was bright, the vehicle I had been driving for two years
( Peugeot 307 1.4 HDI 2004 model .) On the dashboard, dipped beam icon and then the high beam icon flashed. I couldn't understand what it was. then I turned on the headlights and continued on the road but there was no problem. But having this kind of thing caused me trouble, as if it would happen again. Has anyone ever encountered this kind of complaint? I wonder if a solution was found ...
Waiting for your answers ...
Thanks.
08.05.2020 20:53 # 2
talip206
Looks like signal arm malfunction. Was there any sensitivity in the signal? For example, you signaled to the right, while collecting the steering wheel, were there events such as spontaneous signaling to the left?
08.05.2020 20:53 # 3
Aysinsa
YEAH.
I have had this signal arm event since I bought the car, but I didn't care so much because the pejos also said it was a very likely situation.
08.05.2020 20:53 # 4
talip206
[QUOTE = Ayser possible] YES.
As I guessed. The signal arm in our vehicles, airbag winding, wiper arm etc. Sold as a whole. So zero is very expensive. You can have it repaired. The repair option is both easy and economical because there is no problem in your airbag windings.
08.05.2020 20:53 # 5
Aysinsa
Thank you so much. I will discuss this with my electrician friend.
08.05.2020 20:53 # 6
Selcuk55
You can change the headlight arm if your electrician is a good master, just arm is around 100 lira.
08.05.2020 20:53 # 7
Aysinsa
THANK YOU. I WILL SEND THIS TOPIC TO THE ELECTRICIAN FRIEND. CAN IT CHANGE THE ARM ONLY?
08.05.2020 20:53 # 8
[QUOTE = Aysinsa] THANK YOU. I WILL SEND THIS TOPIC TO THE ELECTRICIAN FRIEND. SAY IT CAN ONLY CHANGE THE ARM ... [/ QUOTE]
Teacher is not allowed to write in capital letters due to forum rules. As our friends say, you can just replace the arm, and it will make a good electrician.
