Spontaneous burning quads.
08.05.2020 19:34 # 1
R.CaVuS
Hello friends. My car had burned the top cover gasket and I gave it to the master for repair. When I received the vehicle (vehicle control was broken) I opened the doors with the key. When I switched on and started the ignition, the car started to burn the quads, and from the back it started to sound out. The voice of the opponent was cut off after 30 seconds, and the quadruples were extinguished automatically after 4-5 minutes of moving. This is what it should be when I said this to the master. What is the reason for this, guys? Emergency aid.
08.05.2020 19:34 # 2
talip206
Is there an external alarm system or external remote control in the car. There are situations that you mentioned when you open it with a key, not with a remote control, in the post-mounted controls or alarms. talip206 2015-12-30 21:24:40
08.05.2020 19:34 # 3
R.CaVuS
There is no external alarm system.
08.05.2020 19:34 # 4
KILIC
If the battery has been inserted, it may be necessary to re-synchronize the control. Also, every time you start the car, the quads are burning and a beep sounds. By the way, what is the brand and model of your car.
08.05.2020 19:34 # 5
R.CaVuS
Yes it always comes. 2004 model 307
08.05.2020 19:34 # 6
KILIC
It can give the other sound, because of the cold weather. I think that when the outside temperature was below 3 degrees, I think it was giving a warning when it was first started and it was warning in the meantime. Do not write warnings on the information screen
08.05.2020 19:34 # 7
R.CaVuS
There is no warning on the screen. When you plug in the key to start it, the quads start to light and the sound is heard. The ringing sound stops after 30 seconds, but 4 liters are burning for 4-5 minutes. I think the master has disassembled the battery because the history of the vehicle shows the year 2004 right now.
08.05.2020 19:34 # 8
R.CaVuS
Will it pass if I remove the battery terminals and reset them?
08.05.2020 19:34 # 9
talip206
I think show it to an electrician. my guess is again that the external control, alarm was inserted and canceled, and the master re-attaches the pre-disconnected cable after repair. So all the symptoms show it.
08.05.2020 19:34 # 10
KILIC
The demand is right, it seems to me that there is an external alarm.
