spilling oil behind the right wheel
08.05.2020 19:17 # 1
karadan
Today, when the brake pressures the car, it has overexposed, and when I look at it, the right wheel has always been fat, what could be the reason car pejo 206 x line
by land 2015-05-26 13:23:24
08.05.2020 19:17 # 2
pusutr
The brake center has probably exploded.
08.05.2020 19:17 # 3
seamad
the brake center brother happened to me too it is not a long process, get well soon ...
08.05.2020 19:17 # 4
karadan
Friends, I called the mechanic bsna says Aks, says 350 TL in price.
I'm waiting for your m
08.05.2020 19:17 # 5
karadan
What should change when the brake center explodes
08.05.2020 19:17 # 6
the brake on the wheel may be missing from the hydraulic horn. Check it, let a friend of your vehicle run, check the vehicle and check for a leak. Be absolutely careful, if the brake fluid is discharged, the brakes do not hold. God forbid you can crash. The master may have waved what he has to do with the axle. If there is a leak from the axle, the transmission oil is reduced. Meanwhile, if the brake center is faulty, the brakes will not hold. it may be malfunctioning. brake center or something should be checked, get well in the industry
http://www.peugeotmarket.com/peugeot-206-fren-ana-merkezı-cıfam,pr-2022.html
http://www.peugeotmarket.com/peugeot-206-on-fren-hortumu-orjınal,pr-2018.html
sonerkyl 2015-05-26 18:15:40
08.05.2020 19:17 # 7
pusutr
Go to another master.
Brake center 20-25 tl. twr brand. but change the centers of the two wheels that have changed. So that the braking ratios are the same.
In the meantime, we focused on the rear wheel, but is this oil coming from your front wheel?
Do you also check the shock absorber? Is there oil around?
08.05.2020 19:17 # 8
madblueblacksea
If there is no change in the brakes, the axle bellows has blown out, the master said correctly. If you can't do anything, taste the oil smeared around, grease oil, hydraulic oil. You couldn't do that. There's a lack of hungry hydraulics. I didn't have a room ... make the steering wheel right left and check your hand blower. If the axle blower blew, the master flew a bit. If the 15 TL blower takes 70/80 workmanship, it will give 100 TL more.
08.05.2020 19:17 # 9
madblueblacksea
[QUOTE = what the axle has to do with it, the master may have waved. If there is a leakage from the axle, the transmission oil is reduced
There is no need for the network that escaped from the gearbox to get into the right wheel in any way. The oil is the axle bellows if the circle hood leaps from here to there. Hydraulics throws into a single point and does not move. Tasting the oil is enough to understand this
madblueblackse to 2015-05-26 23:42:41
08.05.2020 19:17 # 10
karadan
The front passenger side wheel, oil thin oil brake hose, I tried clean brakes, it sticks to the ground.
