Speedometer works incompatibly |
| 08.05.2020 19:08 | # 1 |
| 08.05.2020 19:08 | # 2 |
I don't fully understand, but there might be a problem with the panel. |
| 08.05.2020 19:08 | # 3 |
but the electrician understands this. show it to an electrician
| 08.05.2020 19:08 | # 4 |
Efe-Pojo |
Did you compare with GPS?
| 08.05.2020 19:08 | # 5 |
I have compared with GPS, we have looked at other vehicles, but it is wrong. For example, while the end of the 3rd gear is a speed value of 140 in our vehicles, I go up to 115 according to the indicator at the end of the 3rd gear :) the speed value increases as I accelerate :) I think it may be from the mileage sensor friends?
| 08.05.2020 19:08 | # 6 |
Ibre-related
| 08.05.2020 19:08 | # 7 |
I think it has a calibration setting.
| 08.05.2020 19:08 | # 8 |
how can we adjust the calibration?
| 08.05.2020 19:08 | # 9 |
Normally there is a difference of 2 km. but you have a lot of difference. what are your tire diameters original?
| 08.05.2020 19:08 | # 10 |
How can we adjust the calibration of [QUOTE = Erhan_Gti]? [/ QUOTE] I don't know if, but logically, these things have a calibration.
| 08.05.2020 19:08 | # 11 |
I have a rc rim. but the trouble is reaching a value like 140 kmh in 3rd gear, even our vehicles show a value like pointer 115 completely wrong
| 08.05.2020 19:08 | # 12 |
I still couldn't find a solution to the problem.
| 08.05.2020 19:08 | # 13 |
burakbaykal2 |
I had a similar situation, master. I have 206+ 1.4 90 horsepower with a chip, normally 1800 revs, at a speed of 100 kmh in 5th gear, it showed in 90s speed. we found that there was a minor problem. Unfortunately, the sensor and calibration settings are not something you can do, because the set with the indicator on the front panel is removed as it is. After doing the adjustment, the situation in me improved.If you are in Ankara, you can get an appointment from the Peral Peugeot service and give it in the morning and take the car in the evening.You will understand the problem of dealing with something else, so there will be no expenses :)
| 08.05.2020 19:08 | # 14 |
I understand, but I'm in Istanbul, thanks, my master, I need to find a service that can solve this for your half in Istanbul :)
