Speedometer resetting while driving
08.05.2020 21:21 # 1
Hudavendigar34
Hello, friends, I have a problem like this, while the vehicle is in motion, the speed indicator is reset and the airbag light is on, the gas reaction of the vehicle is different, when the car presses and releases it, I would be glad if you have helped for the solution if I have brothers who have encountered this and similar problem before. Thank you.
Vehicle model 206 1.4 HDİ FEVER 2007 model
08.05.2020 21:21 # 2
Exelance86
Hello my friend.
I have the same problem, I have 306 owners. I haven't changed the track yet, but let me transfer my research, I think the problem is with the speed sensor. Sometimes dirt, soil etc. can accumulate or deteriorate directly. It has a price of 150 TL, but some sites cost around 40 TL. There may be quality difference. Suddenly the km hand drops to 0, comes back immediately or comes 2-3 km later, the vehicle does not work on the digital km counter.
08.05.2020 21:21 # 3
Hudavendigar34
I understand, is there any difference in airbag light and gas reaction in your vehicle? Hüdavendigar34 2019-11-08 10:38:24
08.05.2020 21:21 # 4
talip206
[QUOTE = Hüdavendigar34] I understand, is there any difference in airbag light and gas reaction in your vehicle? [/ QUOTE]
Your problem is due to the mileage speed sensor. When the speed drops to zero and the vehicle is in motion, it turns on the airbag lamp. The same thing happened to me. If the speed hand drops to zero and the odometer traveled does not progress or shows less than the distance traveled, the speedometer is malfunctioning.
It is because of the illumination of the airbag light and the motor cumbersome because the ecu, the brain, has a false signal.
08.05.2020 21:21 # 5
fthusl
First of all, get past. The same problem is also present in me, the gas reaction is changing, the speed sensor needs to be changed.
08.05.2020 21:21 # 6
Hudavendigar34
Thank you very much, I will share the result when I take the vehicle to the service for valuable information you provided.
08.05.2020 21:21 # 7
Hudavendigar34
Selam aleykum friends, the speed sensor of the vehicle changed, the original part was bought from the bostancı industry and installed in the vehicle.
