Speedometer Problem |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 207 | |
| 22.09.2022 16:00 | # 1 |
My speedometer dropped below 0(zero) as seen in the photo this morning. It works but falls short of where it should be. Does anyone know how we can fix this? Thank you, |
| 24.09.2022 05:30 | # 2 |
I experienced the same. The jackal masters said from the plumbing - from the indicator, that's why, last time I went and bought a speed sensor. By searching the internet, he had the car lifted to the lift and changed it.. my car is automatic. The inside of the gear, called the speed sensor, is plastic and it breaks over time. If you change it, the problem is solved. It cost me 90 TL in 2020.
| 24.09.2022 19:35 | # 3 |
Thank you for your help, when I started the car a few days later, I saw that it was fixed by chance. If I experience the same fault permanently again, I will remember what you said.
