Speedometer coming behind
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 21:18 # 1
batuhangg
I hit it to run after my car's battery was running out and the pointer remained in a downward position for a while, and it took a while, and now my speed is over 50-60, the pointer starts from 0 to 40-50, but my speed is around 100-110 at that time. . Is there anyone who can live or suggest
08.05.2020 21:18 # 2
tungajo
[QUOTE = batuhangg] I hit it to run on my car's battery run out and the pointer has fallen in a down position for a while, it has been a while, and when my speed is over 50-60, the pointer starts from 0 and slowly goes to 40-50 but my speed is then It's about 100-110. Is there anyone who can live or suggest [/ QUOTE]
Remove the instrument panel.
Remove the gauge glass.
Take out the contact, so it's not a key.
If you turn the hand up, i.e. clockwise, it jumps 2 or 3 cm.
If you do it down, counterclockwise, the sweet tight mil will wrap.
Now you will be adjusted.
You will take it clockwise and bring it to 0 kmm milim milim winding position.
Plug and start the vehicle's ignition. It throws 0-10km late, then shows the actual speed.
Let us communicate.
In the meantime, when you wear a contact, jump back or run
Milim winding, so you have not brought it to the starting position.
Delete it all over again.
08.05.2020 21:18 # 3
tungajo
and be kind to doing this.
08.05.2020 21:18 # 4
batuhangg
I'll try this as soon as possible, thank you
08.05.2020 21:18 # 5
batuhangg
I removed the instrument panel, but since the glass was stuck, I did not try to forcibly remove it due to the possibility of not reinserting it, I tried to access it from the back, but then I left because I could not interfere with the indicators manually
08.05.2020 21:18 # 6
tungajo
If the glass panel does not come out, it should actually come out
What is the vehicle brand model
08.05.2020 21:18 # 7
batuhangg
96 model 406, I tried very hard to remove the glass, but as I said it didn't look like it could come out
08.05.2020 21:18 # 8
tungajo
https://youtu.be/w1hwe_tjzx to
Teacher watch the video there are 7-8 screws on the back
But the cables have to be connected, you have to do it in half contact
Never take off indicator gauges back at idle
Peugeot 406 - Interventions planche de bord
Write youtubeye. Can not open a link.
tungajo 2019-08-31 23:53:47
08.05.2020 21:18 # 9
batuhangg
I also unscrewed those screws, but I think there were screws in the middle, I couldn't separate them because I did not pay any attention to it. Thank you for this interest
08.05.2020 21:18 # 10
tungajo
because i had the same problem
I know how frustrating it is
I hope you do, there is no question in your mind
