Speedometer and petrol gauge malfunction
08.05.2020 21:11 # 1
umydn
Hi friends I am a 2004 model 206 quiksilver 1.6 user. My first Peugeot vehicle. I just bought my car. When I bought it had a few faults and I got them on purpose. The important thing for me was that the engine did not burn oil, and there were no blows, and I found the price I was looking for at an affordable price. Anyway, let me go to the subject without extending much.
Gasoline indicator and Speedometer of the vehicle are not working. I talked to several places, but each one says things separately. Gasoline indicator is occasionally playing When I buy gasoline, the needle plays, then it drops even though I use it in the gas. Sometimes the needle does not play even if I buy gasoline. The speedometer starts at 130km / h. The km / h indicator actually works, but the bar never goes down to 0 at 130-150km / h. I am waiting for your help about price and breakdown.
08.05.2020 21:11 # 2
recepagdas
First of all, the problem came as a wrong intervention, not a malfunction. I have renewed the leds on the 307 min instrument panel before. For this reason, I have information on how the dial is adjusted and how it is opened and collected.
First of all, let's solve whether the gasoline needle moves or does not move. Now even if we go on gas in LPG vehicles, the trip computer drops the needle as if you are constantly consuming gasoline according to instant fuel consumption. Peugeot company did not make a constantly working float system. If he only sees 7-8 liters of play, he will reset the float and measure again, bringing it to the level of gasoline. Since you maybe get 20-30 pounds of benzene, the hand is not reset. First of all, if you clarify here, do you have any problems, or if you are having a situation with everyone, let's look at it. For example, does it increase when you buy 100 lira gas? Does it drop as you use it? (If it is used in gas, it should fall) Even if these two are yes, the drop is not at zero, for example, does it show up in the half tank and get stuck?
Inside the speedometer; Does it come to Zero with the ignition off? Or 130 drops even with the ignition off? Then he counts over 130 as he speeds up? (So when you go with 50, the pointer shows 180?) When you turn off the ignition in one of your working cars, wait for about 20-30 seconds, before opening the doors and the km indicator light should go out. At that moment, there will be a little movement in the hands.
08.05.2020 21:11 # 3
umydn
[QUOTE = recepagdas] teacher first of all the problem was not exactly a malfunction but a malfunction. I have renewed the leds on the 307 min instrument panel before. For this reason, I have information on how the dial is adjusted and how it is opened and collected.
Inside the speedometer; Does it come to Zero with the ignition off? Or 130 drops even with the ignition off? Then he counts over 130 as he speeds up? (So when you go with 50, the pointer shows 180?) When you turn off the ignition in one of your working cars, wait for about 20-30 seconds, before opening the doors and the km indicator light should go out. At that moment, there will be a little movement in the hands, is this happening to you? [/ QUOTE]
When I first bought the car, I bought a 50 TL gasoline. Later, I was not comfortable, I bought a 50 TL gasoline again the next day, because the needle was not working, and there was a little stir. Let me say that even the petrol light did not go out. It just got closer to the quarter.
I immediately turn back to what they asked about km / h and say what I will go to the vehicle and look at. Many thanks for your interest.
08.05.2020 21:11 # 4
umydn
As you said the gas gauge, I bought 100 liters of gasoline and the pointer almost halved. How can we solve this problem?
The speedometer also drops below 110km / h when the ignition is turned off and the light turns off, then turns the ignition back and immediately goes back to above 110km / h. 0km / h does not go down when the contact is closed. It increases as it speeds up.
It drops below 110km / h when the ignition is turned off and the light turns off and then reinsert it and turn the key.
After buying 100 TL of gasoline and on the go, the km / h hand is at 170.
08.05.2020 21:11 # 5
Karacocuk24
[QUOTE = umydn]
[/ QUOTE] I think the gear system inside your display is wrong.It shows that the indicator is removed from the top of the display, then save it from the mosque nails on it, and when the contact is off, the speed indicator will come out carefully before the needle is flexed to the right and left and the bottom of the speed indicator will be below 0, As soon as it lights up, place the light according to the place in which the light is on in 206s.
08.05.2020 21:11 # 6
recepagdas
So it is very difficult, you need to connect it to the computer and adjust it manually according to the value in the brain. Now you can understand that I have to explain this event with video. Nevertheless, I did not write a video and it is very simple.
Now, when the contact closes, all the hands are not zero in the brain? In this case, all your hands must be at the bottom. Whether you are at the bottom of that brain as a brain, you need to bring those needle bars to the bottom. This is happening, the contact is closed and you waited for the km counter to end and extinguished.
You separate the mosque from the indicator. You are turning the needle with your hand to a minimum without exaggerating it. The needle will freeze with internal threads until the bio. When it comes to a minimum, the needle will be blocked. you will apply a little more force and bring it to a minimum, so there is a mile inside the needle. This mile doesn't go back to the minimum. As you turn your needle further, your needle will freeze before the mile freezes, so you will freeze your needle before the shaft freezes.
However, when you hit the needle at the very bottom, the car normally does not hold the bottom 1 mile higher at the bottom, but the brain is at the bottom of the needle, actually 1 mile higher than the bottom you brought when you rotate it with your hand. therefore, when you tamper with the setting, leave it a mile lower, ie leave it as -1 -2, not 0. When you make the contact, when you make a movement to that hand (for example, move the vehicle for your speed hand), you will close the contact again and wait for the screen to end. When the screen is full, the hand will go down to the bottom and reach 1 millimeter. Since you have set -1 -2, the pointer will come to 0 and remain constant at 0. This is the setting for all your hands on the dial. The speed in your gasoline is all the same in the cycle. When setting, the contact should be off and the screen should be out, to see where it will normally come, you should move that hand to the vehicle and turn off the ignition again and wait for the screen to end. Already in case of contact, gas temperature gauges are playing on their own. He's been playing over. If you move it at one, it will play at the speedometer. You can close it and see where the screen stopped last. If you have stopped, the wrong place, you will correct the missing or excessive needle according to your mistake. after a few attempts, you make full adjustments.
I tried to explain it was long but if you can't, I'll take a video.
08.05.2020 21:11 # 7
umydn
Thank you for your attention. I tried to do it myself today, but I couldn't do it. I couldn't get the setting. Later on, there is Anka Elektronik in Ankara Scythians. I went there and explained the situation to the man. He said he could fix it but it would deteriorate again. He said repeatedly, unless you change the engine. I said, let's trust his word and replace the engine. We agreed to 100 TL. He then told me to wait inside while waiting for the car at the start. Anyway, I didn't suspect it at first. When I came in, it came to my mind. Of course, the man had already finished the job until I thought of it. I wanted the old engine too. He told me that he could give me the old engine for 25 TL because they set the price according to him. As you can see, we got ripped off. Be careful. I went to another electrician and had him put on, and the old motor that was not wearing the motor or something is still in place. Let such people do as God knows. Because of these, honest tradesmen are victims.
08.05.2020 21:11 # 8
ismailkaya
what are you doing in your electrician, my friend, you will go to the watchmaker
08.05.2020 21:11 # 9
ismailkaya
Get 50 TL on the dial dustug
08.05.2020 21:11 # 10
recepagdas
Oh, teacher, it was very simple. They do not change the engine or something, even if their engines are very sensitive, they do not make the bicycles 100 lira. Anyway, go without losing that indicator back. LOL we do it back again we Smile
08.05.2020 21:11 # 11
umydn
[QUOTE = ismailkaya] What are you doing in your electrician, my friend, you will go to the watchmaker and gasoline will be lowered under the tank, you will burn gasoline ponpane [/ QUOTE]
There is a subject that everyone is a master of. :) We are novice in these matters. I hope we will learn like this. By the way, Anka Elektronik is making indicator hours. The inside of the shop was filled with Indicators. They were producing themselves.
08.05.2020 21:11 # 12
umydn
[QUOTE = recepagdas] uh, teacher, it was very simple, if you couldn't, I would even throw a video. They do not change the engine or something, even if their engines are very sensitive, they do not make the bicycles 100 lira. Anyway, go without losing that indicator back. LOL we do it back again we Smile [/ QUOTE]
Are you sure ? :) I'll do it, look. What I hate the most in life is that people abuse their knowledge. If that guy said I would fix the needle but I would get 50 TL, I would do it again. Labor is free to say the price it wants, who wants something invaluable. But this is how I wash my shop :)
08.05.2020 21:11 # 13
ismailkaya
When you say watchmakers, you will go to auto watchmakers in the industry.
08.05.2020 21:11 # 14
umydn
[QUOTE = ismailkaya] When you say watchmaker, you will go to the auto watchmaker in the industry.
: D You found it or shoot it as much as you can: D We're not on the wristwatch or wall clock forum anyway: D
08.05.2020 21:11 # 15
ismailkaya
)) I bought the car, I am traveling in the industry, I am in pimpirikli)))) How does the man disassemble the part and I look at it, we are more experienced than the masters in the industry now))
08.05.2020 21:11 # 16
Salomalo
One of the chronic problems of the 206s, the pointer in my old car suddenly went away, sometimes working, misleading the room. I disassembled the eyeball behind the needle gear system, the wheel shaft of the system is broken quickly, I disassembled the gear part, I heated the copper wire of the same diameter and immersed it in the plastic gear cup, I made the shaft by pulling the gear wheels back, the result is positive :) I manually brought it to the 0 position manually, then I went to the traffic for calibration, and open the GPS from the phone. I compared with the speed indicator there, I have deviated, I have collected.
either you will do this or you will get the complete panel .. you can do it if your hand is inclined. I do not think that the fuel gauge is defective, because the brain does not identify when puppetizing in the gas, it may be adjusting the needle according to the km it does.
Salomalo 2019-03-15 22:50:27
08.05.2020 21:11 # 17
umydn
I am too. But I learned that I had a good pile today. The right chassis also had a transaction.
08.05.2020 21:11 # 18
recepagdas
Since the front panel is short, even if there is no bad accident from the front, it requires playing or intervening at the end of the chassis. Do not overdo it. If the chassis is not added to the whole part, the interventions at the end are not a problem. I forgot my right or left in my car, but it's on the end.
08.05.2020 21:11 # 19
umydn
Since the [QUOTE = recepagdas] front panel is short, even if there is no bad accident, it necessitates playing or intervention at the end of the chassis. Do not overdo it. If the chassis is not added to the whole part, the interventions at the end are not a problem. I forgot my right or left in my car, but it's on the end. [/ QUOTE]
Today, I went to Elmasoğulları chassis in Ankara Şaşmaz. Thank you very much, our brother. He said that the problem is not caused by the chassis and is related to the wheel cambers. We fixed the cambers, changed the z rods and made our rot adjustment. We have no problems for now. I'm very glad that the problem is not on the chassis. Unfortunately, I understood once again today. It should not be relied upon to say that I am every master. Everybody was saying something apart. He said that most problems are skewed on the Chassis and that the chassis needs to be fixed. Some of them are broken axles, some of them are out front team. My humble advice is to take it to a single master and don't do everything he says, guys. Ask 3 people Use 1 person logic. Good evening everyone
