Speedometer
08.05.2020 19:58 # 1
Voltranturk
The speedometer is broken for a long time, or even if I make 120km, it remains stuck at 90. After the gasket has burned, the solution and the cost will be thank you in advance.
08.05.2020 19:58 # 2
Cyrus35
My teacher can do it from the sensor. There may also be a problem in the wheel of the indicator engine, you need to make a definitive diagnosis first. To avoid wasting costs, you can first go to a km repairer and show a km engine in the lowest way. Removing the instrument panel is a very simple process anyway.
08.05.2020 19:58 # 3
talip206
the same happened to me
first remove the hat part of the indicator. It will come out if you pull it down to yourself. Then remove the gauge glass, it comes out very easily. pull the indicator hand towards you and sit again. Take the test drive without installing the glass. If it does not happen, press it again and pull it towards you. I tried it 3 or 4 times. This of course is valid for 206. I guess 206 because you did not enter the vehicle information in the information section. talip206 2016-09-19 13:41:18
08.05.2020 19:58 # 4
TooJohn
There is a small motor behind the speed indicator, the speed indicator may not work as a result of the nail being broken, which keeps the wheels moving this motor stationary.
For this malfunction, we have to download the transmission, I met people I do not mean to be a master for his name.
toojohn 2016-09-24 22:49:23
