speed sensor malfunction
08.05.2020 16:33 # 1
narkotik71
If friends speed sensor is available, is there any problem in automatic gear shift in gear changes? Also, low battery voltage is effective in shifting.?
08.05.2020 16:33 # 2
yavuz25
speed sensor means a vital piece. It can even cause a movement to end the transmission. "Exclamati Old battery, useless battery affects the brain of the car, I don't know the man, I don't know about the effect of shifting. "Wink"
08.05.2020 16:33 # 3
fTh206
I don't know what the speed sensor is, I don't know where it is broken & nbsp; "C
08.05.2020 16:33 # 4
yavuz25
It gives the speed information to the automatic transmission that regulates the gears according to the speed.
08.05.2020 16:33 # 5
fTh206
[QUOTE = yavuz25] gives the speed information to the automatic gearbox that regulates the gears according to the speed. [/ QUOTE] For example, it shows how it is broken and how it manifests itself.
08.05.2020 16:33 # 6
yavuz25
[QUOTE = fTh206] [QUOTE = yavuz25] gives speed information to the automatic gearbox that regulates the gears according to the speed. . "Wink"
08.05.2020 16:33 # 7
fTh206
[QUOTE = yavuz25] [QUOTE = fTh206] [QUOTE = yavuz25] gives the speed information to the automatic gearbox that regulates the gears according to the speed. "Wink"
[/ QUOTE] I got it right now Thank God I said it is bad and I don't understand it, then I asked him not to open big things.
08.05.2020 16:33 # 8
narkotik71
thanks.yavuz25.:)
08.05.2020 16:33 # 9
narkotik71
the service had told me that the battery voltage was low, and the car had been able to knock in cold weather. I had asked the battery for it.
08.05.2020 16:33 # 10
yavuz25
Thank you "Smile"
08.05.2020 16:33 # 11
yavuz25
[QUOTE = narcotic71] the service had told me that the low battery voltage was asking the battery for it.
I can't say anything to him. They may be telling the truth, not trading the battery. "Smile"
08.05.2020 16:33 # 12
peugeotefe
The speed sensor has nothing to do with the transmission, the abs readers on the wheels directly related to the abs brain inform the abs brain, allowing the speed hand to work
08.05.2020 16:33 # 13
yavuz25
[QUOTE = peugeotefe] The speed sensor has nothing to do with the transmission, the abs readers on the wheels directly related to the abs brain provide information to the abs brain, allowing the speed pointer to work [/ QUOTE]
I know this speed sensor is transmitting information to the gearbox. "Ermm"
08.05.2020 16:33 # 14
yavuz25
http://www.vwturk.com/forum/showthread.php?60110-OTOMAT%DDK-V%DDTES-HIZ-SENS%D6R%DC
The same problem has occurred in the forum on the link and the transmission problem has been solved with the change of the speed sensor. "Wink"
08.05.2020 16:33 # 15
peugeotefe
In the Peugeot 307, there is no such thing as a speed sensor, friends see the speed by taking information from abs as I just mentioned, this event is different in every vehicle. The plastic part at the end of the supplied crosshead begins to turn the speed sensor so I can send the information to the display clock, I hope I could tell.
08.05.2020 16:33 # 16
yavuz25
[QUOTE = peugeotefe] In the Peugeot 307, there is no part of the speed sensor. As I just mentioned, friends see the speed by getting information from the abs. This event is different in every vehicle. the plastic part at the end of the crosshead box, which allows the axles to rotate in the ground gearbox, begins to turn the speed sensor so that I can send information to the indicator clock. [/ QUOTE]
let's say my brother then changes from vehicle to vehicle. "Wink"
08.05.2020 16:33 # 17
peugeotefe
Yes let's say so :)
08.05.2020 16:33 # 18
yavuz25
[QUOTE = peugeotefe] Yes Let's say :) [/ QUOTE]
"Smile"
08.05.2020 16:33 # 19
mustigiz
Hello,
anybody know about this speed sensor price?
Thank you.
08.05.2020 16:33 # 20
kdryldz123
Well, my teacher, it seems to me that you feel like my vehicle, my car chrysler stratus 98 model's speedometer and counter are not working 244 thousand car rev counter and other indicators are OK. & nbsp; for this reason I can't get it done during the examination. & nbsp; I made the transmission at the shamelessly that it had a triptonic malfunction. & nbsp; says the master I made, about the electrician, not that of us. & nbsp; electrician mechanic's job says: D & nbsp; 1 & nbsp; Go there for months, there is no solution. & nbsp; I thought it might help me thanks in advance. & nbsp;
Page : / 2
