speed sensor
08.05.2020 20:20 # 1
savran03
Hello friends. I think there is a problem with my car's speed sensor. not actively working on the trip computer. I want to change. I wonder if there is a place where we can disassemble it. By the way, my car is a 2003 model.
08.05.2020 20:20 # 2
maximusti
Sir, what exactly is your complaint, I don't understand.
Is your computer not working?
08.05.2020 20:20 # 3
Furkan979
When I say the speed sensor, the dial is broken because there is no section on the trip computer that shows the speed
08.05.2020 20:20 # 4
34dg2030
[QUOTE = savran03] hello guys. I think there is a problem with my car's speed sensor. not actively working on the trip computer. I want to change. I wonder if there is a place where we can disassemble it. Meanwhile my car is 2003 model. [/ QUOTE]
Speed sensor So you are talking about ABS sensors, I think. It measures the speed of the vehicle over the hub bearing in the wheel carrier in the new generation of flat speed vehicles. It does this with the ABS sensor. It is easy to replace the ABS sensor, but since it mostly sees heat, it cannot be boiled (jammed) instead. I think it would be more logical to take it to a master and disassemble it. It is important to note that if the speed sensor is broken, it will directly give the abs fault. In my opinion, do not logically change directly. Have it connected to a diagnostic device and have a look at what is the first fault. Thank you.
