speed rev and gas gauge does not move
08.05.2020 15:05 # 1
sniperElite
In the evening, I left the house and went to the cargo house, passed through a couple of people, but the normal speed breakers took the cargo, went out after a while, the speed cycle and the gas gauge did not move about 10 km. if I don't have a socket connection or ecu ???? do you have any problems?
08.05.2020 15:05 # 2
peugeotefe
What are the models of your Arc?
08.05.2020 15:05 # 3
sniperElite
1998 306 xr 1.8 16v
08.05.2020 15:05 # 4
[QUOTE = sniperElite] I left the house in the evening and went to the cargo house, I went through a couple of coffers, but the normal breakers did not move the cargo, went out after a while, the speed cycle and the gas gauge did not move, I wondered about 10 km, but I did not get any problem. ? if I don't have a socket connection or ecu ???? do you have any problem? [/ QUOTE]
The fuse panel contains a gray and green colored, funny looking fuse. Take it out, wait for a while (1-2 minutes) and put it back in. If you try to see if the indicators are working and write the results here, we will learn.
If you did not find this fuse and you know the radio code or something, remove the battery terminal and wait 5 minutes and reconnect. We expect the results in the same way.
Note: Another method some follow is as follows: Start the vehicle. Insert the battery terminal. Silence the vehicle and replace the battery terminal.
Koliva 2011-02-07 22:38:53
08.05.2020 15:05 # 5
sniperElite
I checked the sigos as you said, I disassembled a few and re-installed them, I started the car, the indicators returned to normal, thank you
08.05.2020 15:05 # 6
feyy
A similar situation has been experienced today.
I opened the subject but it must have been deleted. It would be better if it was not deleted without warning because there was something serious, but appreciated by the managers.
Anyway, only the speedometer is gone. We came only 100-120 km with the rev counter. We came to come, but there is a turn.
It is not a problem though it is a straight road, but one knows it.
I probably can't, but I'll find and show a master. He does it. Hopefully it will get better or our return will be very difficult.
08.05.2020 15:05 # 7
insomnia
[QUOTE = sniperElite] I checked the sigos as you said, I disassembled and reinstalled a few of them, I started the car, the indicators returned to normal thank you [/ QUOTE]
if these conditions are valid for my 306 pug tomorrow
08.05.2020 15:05 # 8
sniperElite
It is not a very difficult thing to check the fuses, open the fuse cover and remove the fuses and play them one by one again.
08.05.2020 15:05 # 9
insomnia
[QUOTE = sniperElite] is not a very difficult thing to check the fuses, open the fuse cover and remove the fuses and play them one by one, and I was almost the master of my car in 4 years 306 xr and 1.8 16v in me [/ QUOTE]
Master, I haven't been able to share the sexuality more than you can understand, it hasn't been even 1 month since 306.
