SPEED PROBLEM !!! HELP PLEASE
08.05.2020 20:36 # 1
dan0ne2
THE FRIENDS HAVE SPEED PROBLEM IN MY VEHICLE 1.4 XLINE 75 HP IS TO BE LIKE LPG 4000 VEHICLES AT 100 SPEED 100 KM / H DIFFERENT HIGH SPEED TO SHIFT UP THERE 3 THROUGH THE SHIFT, THERE IS A SHIFT, THERE IS A SHIFT UP WHEN I WANT TO GO FIXED TO 90 LA, THE TRANSFER IS LIKE AT AT LEAST 3500, I HAVE BREAKED FROM THE VEHICLE PLEASE HELP IT NOW
08.05.2020 20:36 # 2
aykutbayram1996
When was the last maintenance to your vehicle done? What is the hardness of the clutch? Do I miss it? I would recommend you to show a solid master in your vehicle without forcing my 206 doing 3 110 110 in 3 gears.
08.05.2020 20:36 # 3
dan0ne2
[QUOTE = aykutbayram1996] What was the last time your car was done? What is the hardness of the clutch? Do you miss it? I have a definite problem in my vehicle without forcing it to 110 120 in 3 gears. [/ QUOTE]
dear teacher, if your car is xr model it is most likely 90 or 110 hp my 1.4 xline 75 hp at my 3rd gear speed about 60 km / h
08.05.2020 20:36 # 4
Ozgur3310
If the speed is rising but the vehicle is not accelerating, the pressure is over the pad. In other words, if the vehicle is shouting but does not accelerate, the pressure is lining
08.05.2020 20:36 # 5
OguzhanKucuk61
I have a 1.4 75 horsepower model. I watch it with 90 km / h like 2250-2500. My vehicle is driving at a speed of around 110 in the period you mentioned.
it will be a little superior blind, but the increase in engine speed and the correct proportion of speed do not seem like pressure pads.
08.05.2020 20:36 # 6
x571
[QUOTE = dan0ne2] FRIENDS HAVE SPEED PROBLEM IN MY VEHICLE TO BE 1.4 XLINE 75 HP. THERE IS NO PROBLEM, BUT I WANT TO GO FIXED TO 90 LA WITH THIS VEHICLE I HAVE BREAKED AT THE VEHICLE LIKE AT LEAST 3500 AND PLEASE HELP THIS NOW [/ QUOTE]
clutch kit, namely pressure pad. 250 TL part price workmanship whatever God gave: D
08.05.2020 20:36 # 7
ggitaristt
[QUOTE = x571] [QUOTE = dan0ne2] FRIENDS HAVE A PROBLEM IN MY VEHICLE TO BE 1.4 XLIN 75 HP TO LPG WITH 4000 RPG 100 KM / H. I HAVE CHECKED THAT I HAVE NO PROBLEM AS I UNDERSTAND, BUT I WANT TO GO FIXED TO 90 LA WITH THIS VEHICLE, I HAVE BREAKED FROM THE VEHICLE, PLEASE HELP THERE [/ QUOTE]
Nam-i other Big smileBig smile I'm sorry I get stuck on such things
08.05.2020 20:36 # 8
dan0ne2
PROBLEM SOLVED A LITTLE HAPPENED BACK BEHIND LIKE SHOWS 30 KM / H LOW :)))
THE VEHICLE OF THE VEHICLE WAS THE STEERING WHEEL AND VALVE SETTINGS DONE BUTTERFLY THROAT CLEANED FRIENDS THE VEHICLE WAS LIKE THE HOUR I WAS TO DISCOVER THE VEHICLE TongueTongueTongue
Big smile
08.05.2020 20:36 # 9
Oktkor
[QUOTE = dan0ne2] [QUOTE = x571] [QUOTE = dan0ne2] FRIENDS HAVE SPEED PROBLEM IN MY VEHICLE IS 1.4 XLINE 75 HP. THERE IS FALLING THAT I HAVE CHECKED THE CLUTCH CLUTCH, I HAVE NO PROBLEM AS I UNDERSTAND THAT I HAVE BEEN LIKE THAT TO BE LIKE THAT TO BE LIKE THAT TO BE LIKE THAT TO BE LIKE THAT TO BE LIKE THAT TO BE LIKE THAT TO BE LIKE THAT TO BE LIKE THAT TO BE LIKE THAT TO BE LIKE THAT THERE ARE I LIKE THAT THAT I HAVE BEEN LIKE THAT THAT I HAVE BEEN LIKE THAT THAT I HAVE BEEN LIKE THAT THERE ARE I LIKE THAT THERE ARE I LIKE THAT THAT I HAVE BEEN LIKE THAT I HAVE BETWEEN THAT I HAVE LIKED THAT I HAVE LIKED THAT I HAVE BEEN LIKE THAT.
Big smile
Sir I did not understand. Is there a problem in the speed of your car, is there a problem in the indicator? Did he show 80 while he was going with 110?
08.05.2020 20:36 # 10
dan0ne2
[QUOTE = Oktkor] [QUOTE = dan0ne2] [QUOTE = x571] [QUOTE = dan0ne2] FRIENDS HAVE SPEED PROBLEM IN MY VEHICLE 1.4 XLINE 75 HP IS NEEDED AT 4000 RPM WITH LPG, THERE IS NO SPEED AT 3,000 SPEED / H. VITES IS FALLING UP TO 50 KM / H I HAVE CHECKED THE CLUTCH CLUTCH, BUT I HAVE PROBLEM AS I UNDERSTANDED THAT THIS VEHICLE WAS LIKE THAT I HAVE BEEN LIKE THAT THAT THAT I HAVE BEEN LIKE THAT THAT THAT THAT I HAVE BEEN LIKE THAT THAT THAT I HAVE BEEN LIKE THAT THAT THAT I HAVE BEEN LIKE THAT.
Big smile
Sir I did not understand. Is there a problem in the speed of your car, is there a problem in the indicator? Did he show 80 while he was going with 110? [/ QUOTE]
There was a problem in the display, my teacher, but I showed it to the master while he was gone. He said that the valve adjustment is necessary, he works very jerky and he was constantly stating in the morning.
08.05.2020 20:36 # 11
Oktkor
Hodja, there is a difference of 30 km / h. I did not understand how you did not notice.
