speed problem?
08.05.2020 15:57 # 1
semih
mrb 2001 model peugeot 206 rolland garros I have 1.6 engine vehicle in-line system tube vehicle.If you have not exceeded 120 years and 120 years at maximum.
08.05.2020 15:57 # 2
tayfundoner
I do not know much, but if you want to connect to a computer, you can leave it there, I think it shouldn't be done, I think it was made to play in the brain.
Vehicle does not exceed 4000 rpm and 90 km / h does not exceed speed limit
08.05.2020 15:57 # 3
semih
The speed of the vehicle reaches 6 thousand and 7 thousand, but if you force it in 1st gear and second gear, the vehicle gets a little faster. Thank you very much, I will connect you to the computer tomorrow.
08.05.2020 15:57 # 4
Have you ever thought about buying gasoline and trying it ??
The vehicle is straight and I suppose ????
the cecol 2011-08-08 12:54:19
08.05.2020 15:57 # 5
semih
ewet the vehicle has the same problem in the flat gear and we have tried it on the highway on the straight road I tried in hrm gasoline and the tube but there is the same problem. Among ederim.saygı.
08.05.2020 15:57 # 6
tayfundoner
maybe a mechanical problem, get a comment from other friends, wait a little longer will help you.
08.05.2020 15:57 # 7
semih
thanks.
08.05.2020 15:57 # 8
vbmaster
My friend has the same car owner, the same problem disappeared after carbon clean. I also got the butterfly cleaned and it may have an effect.
08.05.2020 15:57 # 9
[QUOTE = semih] ewet the vehicle is in the same gear and you have the same problem on the highway I tried on the highway on the straight road I tried in hrm gasoline and in the tube but there is the same problem. Among ederim.saygı. [/ QUOTE]
Then there must be a problem with your vehicle. A good master must review.
you already reach 120 with the third gear 4e 5e no need Sırıtma
08.05.2020 15:57 # 10
semih
I don't know what carbon clean is. Could you inform me about beer?
08.05.2020 15:57 # 11
[QUOTE = SeMiH]
It is the process of cleaning carbon deposits caused by the use of gasoline in carbon clean cylinders. But I think your problem shouldn't be this ...
If you search on the internet, you can reach detailed information
the cecol 2011-08-08 13:09:01
08.05.2020 15:57 # 12
semih
Jumpstart. Thank you, bidet vehicle in 1st gear and 2nd gear, 4 thousand, but quickly cry.
08.05.2020 15:57 # 13
megez
what color smoke is forced from the exhaust of the sister vehicle
08.05.2020 15:57 # 14
semih
I never looked, believe it
08.05.2020 15:57 # 15
vbmaster
Have you got it connected to the computer? Did something come out?
08.05.2020 15:57 # 16
semih
I'm gonna get it built tomorrow.
08.05.2020 15:57 # 17
my friend is looking at the sente setting ... but i say for sure the same thing is the same event i came to my press 106 quikde the vehicle was not passing 140 meger sent the sente :)))
08.05.2020 15:57 # 18
semih
thank you I will have a look at the industry tomorrow. What happens to you?
08.05.2020 15:57 # 19
vbmaster
If http://forum.peugeotturkey.com/forum_posts.asp?tıd=14973&title=triger-sente-ayar-yanl-ol
The issue is here, but if the sente setting is wrong, the engine knocks ... You should apply the term of handling the engine. God bless. I hope it helps.
08.05.2020 15:57 # 20
What is the state of the oppression?
I could do that too. I had a civic, and it didn't exceed 140.
the pad was finished.
a possibility if he / she is out of pressure.
Page : / 2
