speed problem?
08.05.2020 15:10 # 1
tilbe307
Friends driving on the highway with my car (2003 307 1.6 110hp Atiker Tube) today, when my speed is 170, the car stopped spontaneously.
thank you guys in advance.
08.05.2020 15:10 # 2
tilbe307
Nobody answer Wacko
08.05.2020 15:10 # 3
furkan
where is my shaking steering wheel
08.05.2020 15:10 # 4
tilbe307
the car is shaking completely, my rear wheel is in the bad front silverstone 91 v so is it a bit slow it feels strange cause it does not exceed 170 because it is in the tube briefly cuts off the gas spontaneously ... thanks
08.05.2020 15:10 # 5
cakici9843
It may be from the tube, but I think it is illogical to cut it. I should at least 180 even with 1.6 engine tube
08.05.2020 15:10 # 6
furkan
there can be curvature in the cant or vibrate in curvature of the brake disc, but gas interruption maybe there is a problem in the brain
08.05.2020 15:10 # 7
trtolgi
I saw my car 1.4 90 horsepower lpg li. 180 in the car.
08.05.2020 15:10 # 8
trtolgi
shake the car when it contracts.
08.05.2020 15:10 # 9
metin
[QUOTE = tilbe307] Friends driving on the highway with my car (2003 307 1.6 110hp Atiker Tube) today, when my speed came to 170, the car stopped spontaneously.
thank you guys in advance. [/ QUOTE]
the tool can be connected to the computer and the glue limit may be set to 170. mine was 190 showing 220 i had it built.
08.05.2020 15:10 # 10
xdesign
When my friend reaches 170, is the tachometer red line? or does it cut while staying between 5000-6000?
08.05.2020 15:10 # 11
tilbe307
Let me tell you, even though I rooting the accelerator pedal when the car arrives at 170, it automatically cuts (as if there is a congestion, the gas runs out of the car suddenly or just one by one).
08.05.2020 15:10 # 12
cpirdal
I do not know the speed limit, but the tremor also happens to me ... especially at a speed of 140 km ... I got in my friend's car (ww cady) there was the same thing in it ... They said I had it checked from the tire balance .. I got it set up. The tremor decreased ... But still a little doing though ...
08.05.2020 15:10 # 13
tilbe307
5000 IS AT 6000 RPM. WHEN THIS PASSES, IT'S LIKE A SINGLE AND AUTOMATICALLY REDUCES THE CAR REVOLUTION
08.05.2020 15:10 # 14
tilbe307
08.05.2020 15:10 # 15
axi206
[QUOTE = tilbe307]. [/ QUOTE]
either the ignition or bleeding system as well as the flow meter
08.05.2020 15:10 # 16
tilbe307
There is another situation that I do not understand, sometimes I press it, it sometimes takes a few seconds. I wonder if I connect it to the computer, does it fail?
08.05.2020 15:10 # 17
tilbe307
contact either
