Speed limit
25.03.2021 23:33 # 1
Emre 407
I have a Peugeot 407 vehicle 1.6 hdi cruise control works
Speed limiting (limiting) does not work, pedal changed, fault did not go, brake sensor is intact
Accelerator hardness information fails
I am waiting for help if anyone who knows who has mastered this issue
< div> First of all, the single fault code is p1645
Everything is normal, no problem, no problem.
Only limitation does not work
29.03.2021 09:25 # 2
I recommend you to change the brake switch if it looks like it is intact, sir. a similar problem with brake switch replacement has been fixed.
