Speed increase
08.05.2020 21:04 # 1
Emirseng
Hello friends,
During the gear night, the cycle loads at a time for 2-3 seconds. If I change it at 2500 rpm, it goes up to 3000 at a time. I am sure I will take my foot off the gas. I even tried a vehicle without complaining about a complaint and noticed the room.
No problem when the vehicle is cold.
Why might it be sourced? Did anyone live like this before?
08.05.2020 21:04 # 2
if the car is diesel or petrol + lpg limi teacher.
08.05.2020 21:04 # 3
Emirseng
Diesel teacher
08.05.2020 21:04 # 4
If it is diesel, my teacher has the air meter checked and the air filter and turbo hoses
08.05.2020 21:04 # 5
akk0212
unplug the flow meter, try it, it was similar to me the flow meter was defective. akk0212 2018-11-16 22:23:29
08.05.2020 21:04 # 6
Emirseng
Should I remove the plug and try again? Without it installed?
08.05.2020 21:04 # 7
akk0212
keep the flow meter plugged in, unplug it (keep it unplugged) then drive the vehicle, if the trouble goes, the flow meter may have a problem, clean it, maybe it will recover.
08.05.2020 21:04 # 8
yamanQ
Greetings,
I have the same problem with my car. Where can the flow meter give some more detailed information? Emirseng have you tried what is the last situation?
tşkler.
08.05.2020 21:04 # 9
Emirseng
I haven't tried it yet, but I found your videos on youtube for inserting and inserting. You can find it from there. Flowmeter flowmeter problems appear. Can you write the result if you try
08.05.2020 21:04 # 10
akk0212
it is next to the battery, on the air suction pipe, unplug it without disassembling, use it in such a way that if it improves, remove it and clean it with a cleaning spray.
