Speed hand does not play and vehicle jolts
08.05.2020 17:50 # 1
utku
Hello there. I just joined you. I follow you often, thanks to you, I learned a lot and did a lot.
I have a problem with my car for a few weeks. I wanted to consult you and get your ideas.
My car was 2006 model 206 1.4 hdi. As I move and shift gears when I start the car, as I pull my foot off the clutch and press the throttle, there is a gap and shaking.
There are friends with such problems that I looked at on the site. But my problem is that while this misfire / jerk, the speed hand does not play, so it doesn't work. On top of that, the automatic door locks, which should be closed when activated, do not close. So 3 of them are happening in one. After the car travels 200-300 meters, there is no jerk in the gearshifts, the car makes itself feel like it starts working at the speedometer. I wonder why the trouble stems?
I know I was able to explain clearly. I'm waiting for your help...
