Speed dial problem
08.05.2020 19:27 # 1
muallimsamil
friends before the repair (engine was made) there was no such problem. The speed dial hand is almost straight down. It should be just under 10 I know. my vehicle 2005 206 sw. Did anyone have this kind of problem? solution?
08.05.2020 19:27 # 2
GokhaN
normally it stops at zero if it is directly upright and the display is broken
08.05.2020 19:27 # 3
muallimsamil
it works while cruising, it is not broken. But if you go with a fate of 40, it shows 10, not the actual speed.
08.05.2020 19:27 # 4
GokhaN
[QUOTE = muallimsamil] works while cruising, not broken. But if you go with a fate of 40, it shows 10, not the actual speed. [/ QUOTE]
The room that understands an auto electrician at first is around 1000 minimum for the broken class, the carer or the zero received zero.
08.05.2020 19:27 # 5
telif69
I have the same problem. Remove the glass, pull the needle gently towards you, then push it back to the place you see fit with the same kindness. Is happening. I have done it many times. If you say why you did it over and over again, my 206 has a stop problem. Even the service could not solve it, when I stop on the road, I pull my foot off the clutch and then the needle goes crazy. When the original battery was exhausted, we started pushing it, then the pointer recorded a record of pir ...
08.05.2020 19:27 # 6
muallimsamil
Thanks...
08.05.2020 19:27 # 7
debug
Just like that glass job when the battery runs out easily, it happened to me :))
