Speed Booster.
08.05.2020 15:11 # 1
Ako06
There was an event called Speed Booster. Does anyone know clearly?
08.05.2020 15:11 # 2
AydinBeyol
a program that increases system speed. I've never tried. my advice is to overclock gives clearer results.
08.05.2020 15:11 # 3
[QUOTE = AydınBeyol] is a program that increases the system speed. I've never tried. my advice is to overclock gives clearer results. [/ QUOTE]
is not related to PC, I think the friend asked for the car. & Nbsp; "Laugh"
berkaygr 2011-03-22 21:12:40
08.05.2020 15:11 # 4
CihanHancerli
There is no throttle wire in the 2003 model and above, a simple signal is sent to the throat butterfly of the vehicle. had taken potentiometer IR. Speed (sprint) booster is a piece that accelerates the signal transfer between the car's accelerator pedal sensor and the brain and throat throttle, making your vehicle more responsive to throttle.
Reduces the attack movements or first gas reactions you expect from your vehicle to half periods. In this way, Mini Cooper S also accelerates acceleration of 0-100 in 0.7-0.9 seconds and serializes the cumbership in lower revolutions in low volume or automatic gears by 80%.
08.05.2020 15:11 # 5
CihanHancerli
There is no throttle wire in the 2003 model and above, it sends the signal to the throat butterfly of the vehicle with a simple expression. bought a potentiometer. Sprint booster is a miraculous piece that makes your car more responsive to the throttle by accelerating the signal transfer between the car's accelerator pedal sensor and the brain and throat throttle.
Reduces the attack movements or first gas reactions you expect from your vehicle to half periods. In this way, Mini Cooper S accelerates 0-100 acceleration as 0.7-0.9 seconds in the Mini Cooper S and serializes the cumbership in the lower revolutions of low volume or automatic gear vehicles by 80%.
08.05.2020 15:11 # 6
g-demir
So where and how do we get it?
08.05.2020 15:11 # 7
axi206
My friend has a chıp tuning application on his street, he also installed a sprint booster. sprintbooster made an incredible difference
08.05.2020 15:11 # 8
Eyup Duygun
A product that is beneficial is not bad, but the price performance issue is discussed. It will be more logical to have software for the gas reaction just because it will give you that much money. is it okay ? it is also possible ..
08.05.2020 15:11 # 9
Ako06
Well thank you. I have one more question. Do you have any information about the turbulator and its price?
08.05.2020 15:11 # 10
Eyup Duygun
You're welcome, I don't have any experience about the part you're talking about.
08.05.2020 15:11 # 11
Ako06
thanks.
