speed and speed
08.05.2020 15:15 # 1
helot
My friends' hand is turning at 100 km when the hand of the car is 30a in 5th gear. is this normal (sounds like slow to me) or is there a problem?
Also, a fine sound comes from the engine at a speed of 80 km. If I take my foot off the gas pedal, the sound stops. So when the vehicle is pulling at those speeds, sound is heard.
Zavoli is attached to the vehicle.
08.05.2020 15:15 # 2
The sound from the engine related to the lpg kit comes from your vehicle just like every 307 ..
Everything is fine, nice, I wish I did not see zavoli, so I have not seen any satisfied.
08.05.2020 15:15 # 3
helot
I bought the vehicle 3 days ago, the person before me got it.
08.05.2020 15:15 # 4
106_arts
3b is 100 times normal, 105 should be
08.05.2020 15:15 # 5
helot
thanks for the cvps friends
08.05.2020 15:15 # 6
helot
Does anyone know a good master in manisa? There is this guy, you can even say that when you set the engine to turn off the malfunction lamp. :) It can be not only in the center but also in the districts. I'm sitting in Akhisar.
08.05.2020 15:15 # 7
metin
my car is automatic 4 gear.
4th gear goes to 90 la at 2500 rpm, 4th gear goes to 110 la at 3000 rpm.
08.05.2020 15:15 # 8
toprakk
if you want to show a print liner
08.05.2020 15:15 # 9
[QUOTE = facemelowe] The sound from the engine related to the lpg kit comes from your vehicle just like every 307 ..
this lpg li dye dye is the subject of the injector sound :))
Because there is no part of the injector to make sound related to LPG. Since some injectors are already silent, you can not hear the blade while the engine hood is open while you are on the road :))
in fact, it is a very nice system in zavoli. it seems that you met only those who were not satisfied. We have a friend who has a new zavoli on our system. very satisfied. basically a very nice system in zavoli. injectors are available individually, allowing for precise assembly. good quality in good quality. Of course, every system will be in the poor way as they are not satisfied :)
08.05.2020 15:15 # 10
[QUOTE = 106_arts] 3b is 100 normal count should be 105 [/ QUOTE]
I did not understand what you say should be 105 based on. this changes according to the gear ratio of the vehicle. not every vehicle will be the same. but the equivalent vehicles must be the same ...
08.05.2020 15:15 # 11
[QUOTE = helot] Anyone know a good master in manisa? There is this guy, you can even say that when you set the engine to turn off the malfunction lamp. :) It can be not only in the center but also in the districts. I'm sitting in Akhisar. [/ QUOTE]
Certain fault malfunction burns. If the fault light burns only after the LPG is over, it means the wrong LPG mixture. this will also damage the engine ... the fault temperature does not light in the proper lpg setting ...
08.05.2020 15:15 # 12
tugrahan
hi my friend
If I remember correctly in manisa, one of the forum members (peugeot murat)
Our user named peugeot was a special service by phone
I asked something about my vehicle is a related friend
but I was not very active, I did not try to reach through the site, I will give your phone
08.05.2020 15:15 # 13
106_arts
[QUOTE = cecoli] [QUOTE = 106_arts] 3b is 100 normal counts 105 should be [/ QUOTE]
I do not throw it off I got on the same engine 206, I got the same speed on the gearbox at that time.
What is the size of the wheel rim that may deviate in the high probability indicators?
106_arts 2011-04-10 23:41:27
08.05.2020 15:15 # 14
[QUOTE = 106_arts] [QUOTE = cecoli] [QUOTE = 106_arts] 3b is 100 normal count should be 105 [/ QUOTE]
the engines are the same but I can't cut the gear ratios ...
however, the face indicator is not affected by changing the tire cap. Because the km sensor is on the transmission. If the rubber cap changes, the real face changes. but the indicator shows the same. cap buyurse will have more smileys than the indicator. the opposite is true if it is fitted small. It will move in the same way in km counter ...
some taxi drivers wear small tires and print more kms at the same distance to make more money.
the cecol 2011-04-10 23:49:14
08.05.2020 15:15 # 15
se®k@n
If your car is gasoline, it is normal. If it is diesel, the speed should be higher in those times.
08.05.2020 15:15 # 16
helot
I just started the car, put it on gas, but the engine malfunction lamp did not stop. Soner maybe not working for 5 minutes if it worked a bit long on gasoline, I don't know. In addition, after 6 thousand cycles, the car is shaking, there is no shaking even up to 6 thousand.
Thank you for your comments, I am curious about everything since I just bought the vehicle.
08.05.2020 15:15 # 17
you will not gas like you do mars on gas ... I guess it is probably due to malfunction. If there is no end of the exercise, it says there is a problem elsewhere. It is necessary to connect and look at the tool ...
After 6000 cycles, I don't want to bounce anymore :) You can get 6000 above you :))
08.05.2020 15:15 # 18
marasov
I opened this subject, my vehicle is 5 km in 2500 rpm at 100 km speed
08.05.2020 15:15 # 19
helot
I wait for a long time to accelerate after starting the car. If I do not wait, if I act on gasoline, it will be a problem if it passes on the gas!
08.05.2020 15:15 # 20
[QUOTE = helot] I wait for a long time to accelerate after starting the car. If I do not wait, if I act on gasoline, it will be a problem if it passes on the gas! [/ QUOTE]
no you don't have to wait. Continue slowly, 10 seconds after starting the vehicle. While you wait where you stop, you will be on the road with your gasoline ... You don't know that you're going through the situation.
Page : / 2
